My thermostat doesn't switch the relays on and off properly. As best as I can tell the code says to do it the way I want.
What it is supposed to do
Cooling Mode
Turn off the red LED
Turn on the Blue LED
Display the current temp and set temp
If the set temp is higher than the current temp
then turn off the heat relay
turn on the fan relay
turn on the cool relay
if the set temp is lower than the current temp
then turn off the cool relay
Heating Mode
Turn off the blue LED
Turn on the red LED
Display the current and set temp
If the set temp is lower than the current temp
then turn on the fan relay
turn on the heat relay
turn off the fan relay
What it does
Cooling Mode
Current and set temps are displayed
Blue LED comes on and the red LED goes off
heat relay comes on
fan relay comes on
cool relay goes off
if the set temp is higher than the current temp
heat relay stays on
cooling relay comes on
fan relay goes off
Heating Mode
Displays current and set temp
Blue LED goes off and red LED comes on
If set temp is lower than current temp
heat relay comes on
fan relay comes on
cool relay stays off
if set temp is higher than current temp
heat relay stays on
fan relay stays on
As seen here -----> Trouble with thermostat code (arduino) - YouTube
/* A fair portion of the code here is from Arduinotronics and I would have been lost with out it. This is my first “big” Arduino project. So, there is probably a ton of things that can be improved on and tweeked. I would love to know your thoughts and see your improvements! If you would like to share your thoughts with me on this please email me at modsbyus at modsbyus dot com and make the subject line RE: Arduino Thermostat Thoughts, or write a comment on the tutorial at http://www.modsbyus.com/diy-arduino-thermostat/ */
#include <OneWire.h> //This temperature sensor requires a 4.7k Ohm resistor across its pins 2 and three!!!!
#include <DallasTemperature.h>
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h> // F Malpartida's NewLiquidCrystal library
#define I2C_ADDR 0x20 // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 7
#define En_pin 4
#define Rw_pin 5
#define Rs_pin 6
#define D4_pin 0
#define D5_pin 1
#define D6_pin 2
#define D7_pin 3
#define LED_OFF 0
#define LED_ON 1
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
int sensorPin = A0; // select the input pin for the 10K potentiometer
int sensorValue = 0; // variable to store the value coming from the sensor
int setTemp = 0; // variable to store temp desired
int SSRCPin = 5; //Turn on A/C unit
int SSRHPin = 6; //Turn on heat (electric or gas)
int hcLED = 4; //indicator for Cooling mode
int SwitchPin = 3; // To switch between Cooling and Heating
int SSRFan = 7; // To turn on and off the air handler fan
char* heat;
float currentTemp = 0;
//This temperature sensor requires a 4.7k Ohm resistor across its pins 2 and three!!!! Thats the middle pin and the GND pin
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer = { 0x28, 0xAF, 0x51, 0x6C, 0x04, 0x00, 0x00, 0x22 };
// DeviceAddress outsideThermometer = { 0x28, 0x20, 0x04, 0xA8, 0x02, 0x00, 0x00, 0x4D };
void setup(void)
// Start up the library
sensors.begin();
// set the resolution to 9 bit (good enough?)
sensors.setResolution(insideThermometer, 9);
// sensors.setResolution(outsideThermometer, 9);
lcd.begin (16,2); // columns, rows. use 16,2 for a 16x2 LCD, etc.
pinMode(SSRFan, OUTPUT); //set airhandler fan pin as output
digitalWrite(SSRFan, LOW);
pinMode(SSRHPin, OUTPUT);
digitalWrite(SSRHPin, LOW);
pinMode(SSRCPin, OUTPUT);
digitalWrite(SSRCPin, LOW);
pinMode(hcLED, OUTPUT);
digitalWrite(hcLED, LOW);
pinMode(SwitchPin, INPUT);
void printTemperature(DeviceAddress deviceAddress)
sensors.requestTemperatures(); // was in loop
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
lcd.print("Error");
// lcd.print(tempC);
// lcd.print("/");
currentTemp = (DallasTemperature::toFahrenheit(tempC));
lcd.print(currentTemp);
void loop(void)
sensorValue = analogRead(sensorPin);
setTemp = sensorValue / 10.24; //Gives us a set temp range between 0 and 99 degrees
//lcd.clear(); // start with a blank screen
lcd.setCursor(0,0);
lcd.print("Current:");
lcd.setCursor(0,1);
lcd.print("Set:");
//lcd.setCursor(0,3);
//lcd.print("Heat: ");
lcd.setCursor(8,0);
printTemperature(insideThermometer);
lcd.setCursor(6,1);
lcd.print(setTemp);
//lcd.setCursor(7,3);
//lcd.print(heat);
//Cooling Mode
int val = digitalRead(SwitchPin) ;// val represents digitalRead(SwitchPin);
// If the value of is 1 then make hcLED low (off) which sets the relay in a normally closed state. Hence, turning on the blue LED.
if (val == 1)
/* If the SwitchPin reads 1 and the current temperature is greater than the set temperature (if its hot) turn on the A/C and internal fan */
if (val == 1 && (currentTemp > setTemp))
digitalWrite(SSRFan, HIGH);
digitalWrite(SSRCPin, HIGH);
/* Otherwise, if the SwitchPin reads 1 and the current temperature is less than the set temperature (the set temperature has been reached), turn off the A/C and internal fan */
else if (val == 1 && (currentTemp < setTemp))
// Heating Mode
// If the value of is 0 then make hcLED HIGH (on) which sets the relay in a normally open state. Hence, turning on the RED LED
if (val == 0)
digitalWrite(hcLED, HIGH);
/* If the SwitchPin reads 0 and the current temperature is less than the set temperature (if its cold) turn on the HEAT and internal fan */
if (val == 0 && (currentTemp < setTemp))
digitalWrite(SSRHPin, HIGH);
/* If the SwitchPin reads 0 and the current temperature is greater than the set temperature (the set temperature has been reached) turn off the HEAT and internal fan */
else if (val == 0 && (currentTemp > setTemp))
