I previously posted a question about interrupts, and since managed to get them working. However, I am getting some weird behaviour.
When I press the button, the program doesn't seem to go back to the loop, rather the screen goes blank. The interrupt still works, as if I put a serial output in it, it shows that it is being pressed, but it doesn't seem to go back to the program.
The code is below:
float Version = 0.7;
//Settings
int pulsesPerRev = 4;
int pulsesPerRot = 6;
/*Wheel circumference in metres*/
double wheelCircumference = 1.5;
//Libraries
#include <EEPROM.h>
#include <LiquidCrystal.h>
//LCD Pins
int rs = 32;
int enable = 33;
int d4 = 34;
int d5 = 35;
int d6 = 36;
int d7 = 37;
//LCD Initialisation
LiquidCrystal lcd(rs,enable,d4,d5,d6,d7);
//Pins
//Digital
int RPMPin = 41;
//Analog
int lambdaPin= 0;
int Temp1Pin = 1;
int Temp2Pin = 2;
//Interrupts
/*The line from the speedometer should be attached to digital 2.
The line from button 1 should be attached to digital 3.
The line from button 2 should be attached to digital 21. */
//Variables to be loaded from EEPROM
int setting = 0;
int imperialMetric = 0;
/* The total distance travelled in m. */
double TotalDistance = 0;
//External Variables
int numberOfSettings = 2;
int newDisplay = 456;
double speed;
volatile int numPulses = 0;
volatile unsigned long pulseDebounce;
volatile unsigned long buttonDebounce;
unsigned long lastSpeedTime;
int rpmSample = 1000;
void setup(){
//Start LCD
lcd.begin(16,2);
//Setup interrupts.
attachInterrupt(0,pulse,RISING);
attachInterrupt(1,button1Press,FALLING);
attachInterrupt(2,button2Press,FALLING);
//Display startup on LCD
lcd.print("Speeduino");
lcd.setCursor(0,1);
lcd.print("Version ");
lcd.print(Version);
delay(2000);
lcd.clear();
pinMode(RPMPin,INPUT);
void loop(){
unsigned long timer;
if (setting == 0) displayODO();
if (setting == 1) displayRPM();
if (millis() > timer + 1500){
updateSpeedDist();
timer = millis();
void pulse(){
if (millis()> pulseDebounce + 100) {
numPulses++;
pulseDebounce = millis();
void button1Press(){
if (millis()>buttonDebounce+100) {
setting++;
setting = setting % (numberOfSettings);
buttonDebounce = millis();
void button2Press(){
imperialMetric++;
imperialMetric = imperialMetric % 2;
newDisplay = 897;
void updateSpeedDist(){
unsigned long newSpeedTime = millis();
double speedMps = (((double)numPulses/(double)pulsesPerRot)*wheelCircumference)/(((double)newSpeedTime - (double)lastSpeedTime)/1000);
speed = speedMps * 2.23693629;
double newDist = (((double) numPulses/(double)pulsesPerRot)*wheelCircumference);
TotalDistance = newDist + TotalDistance;
numPulses = 0;
int getRPM(){
unsigned long time = millis();
int voltage = 1;
int previousRead = 0;
int newtime = millis();
int revCount = 0;
while (newtime < time + rpmSample){
voltage = digitalRead(RPMPin);
if ((voltage==HIGH)&&(previousRead==0)) {
revCount++;
previousRead = 1;
else if (voltage == LOW){
previousRead = 0;
return (int)((((double)revCount/(double)((double)rpmSample/1000))*60)/(double)pulsesPerRev);
void displayODO(){
if (newDisplay != 0){
lcd.clear();
newDisplay = 0;
lcd.setCursor(0,0);
if (imperialMetric == 0){
lcd.print("Speed: ");
lcd.print(speed);
lcd.print("mph");
lcd.setCursor(0,1);
lcd.print("Dist: ");
lcd.print((TotalDistance*0.000621371192));
lcd.print("M");
if (imperialMetric == 1){
lcd.print(speed*1.609344);
lcd.print("kph");
lcd.setCursor(0,1);
lcd.print(TotalDistance*0.0001);;
lcd.print("km");
void displayRPM(){
if (newDisplay != 1){
lcd.clear();
newDisplay = 1;
int rpm = getRPM();
lcd.setCursor(0,0);
lcd.print(speed);
lcd.print("mph");
lcd.setCursor(0,1);
lcd.print("RPM: ");
lcd.print(rpm);
lcd.print("kph");
lcd.setCursor(0,1);
lcd.print("RPM: ");
lcd.print(rpm);
I only have button 1 connected at the moment, but I don't see why that would make any difference.
Thanks ![]()
