Don't really know if this is the best location to pose this question, so move if needed.
I am currently working on a project with a Duemillanova. To this I need to attach an Ethernet shield (using pins 10-13) and an LCD shield (using pins 4-9). This leaves me with pin 0-3. Exactly enough for my purposes, if not that 0 and 1 are hardwired to TX/RX which interferes.
Am I stuck here or are there solutions to this problem? This scheme shows the apparent use of analog pins as output, but I do not see this being supported in the Reference.
BTW: for the testing phase I'll drive LEDs with the pins, later on these will be (probably transistor driven) solid state releais.
Any help is hugely appreciated.
