More question about L293D
I have a monster RC truck. I want to modify it to to use the Arduino to control it to go forward and backward. I followed this tutorial https://learn.adafruit.com/downloads/pdf/adafruit-arduino-lesson-13-dc-motors.pdf, everything works fine on a small motor.
I gave pin8 an external power-9.6v 1250A NiMH battery ( the battery used on the truck.) to power the large motor of the truck, the motor gets only half the speed and it gets so hot that it can toast a peanut!. Upon reading up the data sheet of the L293D, I realized the L293D only provides current up to 600mA. Is this why the motor doesn’t run in full RPM?
If so, can someone recommend a chip has similar function of the L293D but can provide at least 1.5 A current? (Even the L293, can only provide up to 1A of current, according to the data sheet.)
Any suggestion will be greatly appreciated. :slight_smile:
