More sensitive "EMF detector" circuit?
Hello,
I have built and EMF detector project using this tutorial:
It functions but is not very sensitive. I was wondering if anyone had any suggestions for a way to use the same code, but improve on the sensitivity with hardware or code or a combination of both?
Any assistance would be greatly appreciated :slight_smile:
// EMF Detector for LED Bargraph v1.0
// 5.12.2009
// original code/project by Aaron ALAI - aaronalai1@gmail.com
// modified for use w/ LED bargraph by Collin Cunningham - collin@makezine.com
#define NUMREADINGS 15 // raise this number to increase data smoothing
int senseLimit = 15; // raise this number to decrease sensitivity (up to 1023 max)
int probePin = 5; // analog 5
int val = 0; // reading from probePin
int LED1 = 11;  // connections
int LED2 = 10;  // to
int LED3 = 9;   // LED
int LED4 = 8;   // bargraph
int LED5 = 7;   // anodes
int LED6 = 6;   // with
int LED7 = 5;   // resistors
int LED8 = 4;   // in
int LED9 = 3;   // series
int LED10 = 2;  //
// variables for smoothing
int readings[NUMREADINGS];                // the readings from the analog input
int index = 0;                            // the index of the current reading
int total = 0;                            // the running total
int average = 0;                          // final average of the probe reading
  pinMode(2, OUTPUT);  // specify LED bargraph outputs
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  Serial.begin(9600);  // initiate serial connection for debugging/etc
  for (int i = 0; i < NUMREADINGS; i++)
    readings[i] = 0;                      // initialize all the readings to 0
  val = analogRead(probePin);  // take a reading from the probe
  if(val >= 1){                // if the reading isn't zero, proceed
    val = constrain(val, 1, senseLimit);  // turn any reading higher than the senseLimit value into the senseLimit value
    val = map(val, 1, senseLimit, 1, 1023);  // remap the constrained value within a 1 to 1023 range
    total -= readings[index];               // subtract the last reading
    readings[index] = val; // read from the sensor
    total += readings[index];               // add the reading to the total
    index = (index + 1);                    // advance to the next index
    if (index >= NUMREADINGS)               // if we're at the end of the array...
      index = 0;                            // ...wrap around to the beginning
    average = total / NUMREADINGS;          // calculate the average
    if (average > 50){                // if the average is over 50 ...
      digitalWrite(LED1, HIGH);   // light the first LED
    else{                         // and if it's not ...
      digitalWrite(LED1, LOW);    // turn that LED off
    if (average > 150){               // and so on ...
      digitalWrite(LED2, HIGH);
    else{
      digitalWrite(LED2, LOW);
    if (average > 250){
      digitalWrite(LED3, HIGH);
    else{
      digitalWrite(LED3, LOW);
    if (average > 350){
      digitalWrite(LED4, HIGH);
    else{
      digitalWrite(LED4, LOW);
    if (average > 450){
      digitalWrite(LED5, HIGH);
    else{
      digitalWrite(LED5, LOW);
    if (average > 550){
      digitalWrite(LED6, HIGH);
    else{
      digitalWrite(LED6, LOW);
    if (average > 650){
      digitalWrite(LED7, HIGH);
    else{
      digitalWrite(LED7, LOW);
    if (average > 750){
      digitalWrite(LED8, HIGH);
    else{
      digitalWrite(LED8, LOW);
    if (average > 850){
      digitalWrite(LED9, HIGH);
    else{
      digitalWrite(LED9, LOW);
    if (average > 950){
      digitalWrite(LED10, HIGH);
    else{
      digitalWrite(LED10, LOW);
    Serial.println(val); // use output to aid in calibrating
arduinokov: I was wondering if anyone had any suggestions for a way to use the same code, but improve on the sensitivity with hardware or code or a combination of both?
Any assistance would be greatly appreciated :)
Which Arduino board do you use? UNO? MEGA? Or a different board?
Thank you very much for taking the time to answer. I am using an Uno for breadboarding, then a Pro Mini in my project.
arduinokov: I am using an Uno for breadboarding, then a Pro Mini in my project.
So it's an Atmega328 and you can increase the sensitivity of the "analogRead()" function by setting the analog reference voltage to INTERNAL (1.1 volts internal reference).
With Atmega328 based board include this line in your setup() function:
analogReference(INTERNAL);
The internal working is, that the analogRead() function measures 0 with 0V and 1023 with just 1.1V (instead of 1023==>VCC=5V).
So less voltage will lead to higher analogRead() readings.
If you do so, do you find then that the sensitivity of your detector has increased?
Thanks, I will give it a try!
:smiley:
It worked with my Mega using analogReference(INTERNAL1V1);
thanks, it is more sensitive now.
