hi everyone,
I have been working to write on SD card to my datas (Accelerometer and GPS). There are people who recommend the SDFat library, but I couldn't do that. I'm writing my code below. I expect your help. Thanks in advance...
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <TinyGPS.h>
File dosya;
TinyGPS gps;
LiquidCrystal_I2C lcd(0x27, 16, 2);
#ifndef GPSport_h
#define GPSport_h
#define gpsPort Serial1
#define GPS_PORT_NAME "Serial"
#define DEBUG_PORT Serial1
#endif
const int MPU_addr = 0x68;
unsigned long previousMillis = 0;
const long interval = 30;
float XAxisFinal;
float YAxisFinal;
float ZAxisFinal;
float ang_x;
float ang_y;
float ang_z;
int X_offset = 0;
int Y_offset = 0;
int Z_offset = 1700;
unsigned long simdikizaman;
const int chipSelect = 10;
Serial.print("Initializing SD card...");
Serial1.begin(9600);
lcd.begin();
lcd.clear();
lcd.print("Hiziniz:");
lcd.setCursor(8, 1);
lcd.print("km/saat");
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B);
Wire.write(0x00);
Wire.endTransmission(true);
simdikizaman = millis();
int sensorState = analogRead(A0);
smartdelay(0);
uint8_t sat = gps.satellites();
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
int spd = gps.f_speed_kmph();
int year;
byte month, day, hour, minute, second, hundredths;
unsigned long age2;
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age2);
lcd.setCursor(0, 1);
lcd.print(spd);
///////accelerometer
if (currentMillis - previousMillis >= interval) {
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 6, true);
int16_t XAxisFull = (Wire.read() << 8 | Wire.read()) + X_offset;
int16_t YAxisFull = (Wire.read() << 8 | Wire.read()) + Y_offset;
int16_t ZAxisFull = (Wire.read() << 8 | Wire.read()) + Z_offset;
XAxisFinal = (float) XAxisFull / 16384.0;
YAxisFinal = (float) YAxisFull / 16384.0;
ZAxisFinal = (float) ZAxisFull / 16384.0;
ang_x = atan(YAxisFull / (sqrt(pow(XAxisFull, 2) + pow(ZAxisFull, 2)))) * 57296 / 1000;
ang_y = atan(XAxisFull / (sqrt(pow(YAxisFull, 2) + pow(ZAxisFull, 2)))) * 57296 / 1000;
Serial.print("sat: "); Serial.print(sat);
Serial.print("\t");
Serial.print("spd: "); Serial.print(spd);
Serial.print("\t");
Serial.print("lat: "); Serial.print(flat, 6);
Serial.print("\t");
Serial.print("\t");
Serial.print("lon: "); Serial.print(flon, 6);
Serial.print("\t");
Serial.print("\t");
Serial.print("hour: "); Serial.print(hour + 3);
Serial.print("\t");
Serial.print("minute: "); Serial.print(minute);
Serial.print("\t");
Serial.print("second: "); Serial.print(second);
Serial.print("\t");
Serial.print(Rfinal);
Serial.print("\t");
Serial.println(sensorState);
//////////////// SD CARD
dosya = SD.open("myfile.txt", FILE_WRITE);
//dosya.print(saat.dayofmonth);
//dosya.print(".");
//dosya.print(saat.month);
//dosya.print(".");
//dosya.print(saat.year);
//dosya.print("--");
//dosya.print(saat.hours);
//dosya.print(":");
dosya.print("sat: "); dosya.print(sat);
dosya.print("\t");
dosya.print("spd: "); dosya.print(spd);
dosya.print("\t");
dosya.print("lat: "); dosya.print(flat, 6);
dosya.print(" ");
dosya.print("lon: "); dosya.print(flon, 6);
dosya.print("\t");
dosya.print("minute: "); dosya.print(minute);
dosya.print("\t");
dosya.print("second: "); dosya.print(second);
dosya.print("\t");
dosya.print(simdikizaman);
dosya.print("\t");
//dosya.print(ZAxisFinal);
//dosya.print("\t");
dosya.print(Rfinal);
dosya.print("\t");
dosya.println(sensorState);
dosya.close();
static void smartdelay(unsigned long ms) {
unsigned long start = millis();
do {
while (Serial1.available())
gps.encode(Serial1.read());
} while (millis() - start < ms);
