More than 1 value
Hello,
My name is Jessy.
I’m trying to send more than 1 values from Arduino to Processing over Serial.
But what is the best method of sending them from the Arduino, and receiving it on Processing?
I know how to send 1 value, but when there is more coming over the Serial line, then i don’t know how to let Procesing pick up the second value.
This is what i have now, just for testing.
ARDUINO:
int potPin = A0;
  int val = map(analogRead(potPin), 0, 1023, 0, 255);
  Serial.println(val);
PROCESSING:
import processing.serial.*;
import controlP5.*;
Serial port;
float hoogte = 0;
  size(500, 500);
  background(120);
  port = new Serial(this, "COM3", 9600);
  port.bufferUntil('\n');
void draw() {
  background(120);
  rect(125, 400, 50, -hoogte);
void serialEvent (Serial port) {
  hoogte = float(port.readStringUntil('\n'));
Now i want to add a LDR to my Arduino, but i don’t know how to let Processing know, which value that is.
So that i can make a second rect with the second value from the serial line.
Could anyone help me? :slight_smile:
Thanks in advance.
When sending multiple values there are a number of ways to distinguish between them
  • Always send the values in the same sequence with some means to determine one sequence from the next. This can be a time gap of some minimum length or a unique value.
  • Have a identifier preamble each value. That way you are not bound to the sequence but decoding is more complicated
  • Use the msb to distinguish between control and data bytes. This limits the transfer to 7 bits/byte instead of 8
Since you are sending the data as text,
Serial.print(firstValue);
Serial.print(",");
Serial.println(secondValue);
In Processing, use the port.readStringUntil('\n') method, to read the data into a String. Then, use the split() method to split the string into an array of ints (not floats, since you are NOT sending floats).
