More than one 74HC595
hi all,
cant figure it out how to write code for more than one 74HC595.
I want connect 16 leds and make fade effect using 74HC595.
my code for one 74HC595:
int latchPin = 8; // 74HC595 leg 12
int clockPin = 12; // 74HC595 leg 11
int dataPin = 11; // 74HC595 leg 14
int outputEnablePin = 3; // 74HC595 leg 13
byte leds = B10010001;
byte b = 0;
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(outputEnablePin, OUTPUT);
    digitalWrite(latchPin, LOW);
    shiftOut(dataPin, clockPin, MSBFIRST, leds);
    digitalWrite(latchPin, HIGH);
    //delay(1000);
    for (b = 0; b < 256; b++)
    setBrightness(b);
    delay(10);
    if(b == 255) {
      delay(2000);
void setBrightness(byte brightness) // 0 to 255
  analogWrite(outputEnablePin, 255 - brightness);
If I wire another 74HC595 and run code the other 8 leds do the same fade but with random leds. If I upload same code again firs 8 leds work fine but other 8 random again and do the same fade.
How can I define each 74HC595 x 2 output from 0 to 15 in code?
You're only shifting data to one chip here
Add a 2nd shiftout()
     shiftOut(dataPin, clockPin, MSBFIRST, more_leds);
and come up with data for more_leds.
oh man you are amazing! Thank you!
You're welcome. Pretty simple so far tho ...
