This is a follow-on to the thread on timing with a external interrupt and a square wave. Here's what I've got:
INPUT - IR pulse from Andromeda Space Rocker -> simple detector -> pin 2
DESIRED OUTPUT:
- Three pluse trains, using three out pins (Atm, 11-13), simple LED out.
- A - same rate as input
- B - twice the rate
- C - three times the rate.
I used the example from a previous discussion, where the ISR sets
a flag, and the main loop does the work.
Current plan-
- Interrupt sets a flag
- if (flag) get time from millis(), subtract from previous
- keep running average for smoothness
This code more-or-less works, but I'd really like to smarten it up a bit.
Also, I get a compile error unless CheckAndClearFlag is defined before being called, which I don't understand..
Submitted for your disapproval....
// sketch to receive an input clock signal on pin 2
// determine average clock rate
// blink LEDs on 1/3, 1/2 note
byte CheckAndClearFlag( volatile byte& Flag )
byte Result;
uint8_t SaveSREG = SREG;
cli();
Result = Flag;
Flag = false;
SREG = SaveSREG;
return( Result );
volatile byte clockFlag = false; //Interrupt flag
unsigned clockCount = 0; //interrupt counter
long prevbase=0;
long prev2 = 0;
long prev4 = 0;
long curtime = 0;
int arprate = 300;
long mtime = 0;
long lastime = 0;
long deltatime = 0;
long count = 0;
long tottime = 1;
int sensePin = 2;
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
pinMode(11,OUTPUT);
pinMode(sensePin, INPUT);
attachInterrupt(0,clock,RISING);
curtime = millis();
if (curtime - prevbase >= arprate ) { //everybody trips on the beat
prevbase = curtime;
digitalWrite(13, HIGH);
digitalWrite(12, HIGH);
digitalWrite(11, HIGH);
delay(5);
digitalWrite(13, LOW);
digitalWrite(12, LOW);
digitalWrite(11, LOW);
} else if (curtime - prev2 >= (arprate/2) ) { // 2x the beat
prev2 = curtime;
delay(5);
} else if (curtime - prev4 >= (arprate/3) ) {
prev4 = curtime;
delay(5);
// Figure out the average time.
// Only redo our clock if we have an interrupt
if ( CheckAndClearFlag( clockFlag )){ //Only need to go through if a new interrupt has been triggered
delay(2); //Debounce interrupt input
cli();
clockFlag = false;
SREG = SaveSREG;
// the delta between now, and the last time we hit interrupt + loop time.
mtime = millis();
deltatime = mtime - lastime;
lastime = mtime;
// Do the average
tottime = tottime + deltatime;
count++;
arprate = tottime/count;
constrain(arprate, 200, 2000); // 200 = 300 bpm, 2000 = 30 bpm
// Clear our totals so tottime does not overflow
if (count > 3) {
count = 0;
tottime = arprate;
void clock(){
clockFlag = true; //Interrupt routine
