morphing arrays
Hi all!
I'm having troubles to come up with a way to approach this problem:
I want to morph 2 diferente arrays and "move" the results to a 3rd array.
The morphing factor would be dependent on the value of a Pot. Array A would be at CW positon and array B at CCW potentiomter positon.
Any clues on how to approach this? Not asking for code, just some enlightenment on which way to go :slight_smile:
Thanks in advance
Please explain what you mean by "morphing arrays".
is "morphing" a technical term?
eager to find out
Yes, "morphing" is not the right word. Sorry about this
I believe the better term would be cross-fade.
do you mean weighted average
K < 1
c [n] = K * a[n] + (1-K) * b [n]
blinkings:
Rather than trying to find the right word, which might or might not exist, it would help if you could describe what you want and include an example of before and after to illustrate what you want. Don't forget the code tags!
Perhaps it would help if you gave an example.... an array 12345 say and another abcde and then show first how the pot determines where the break occurs, and second what the resulting array should be.
I'm keen to know what it means for a pot to have a CW and CCW position.
