I am pretty new to programing and I'm trying to build a morse code encoder/decoder. While building the encoder I've come across a problem storing the dots and dashes. Everything seems to be working except saving 1's or 2's to the "Position" variables. I presume that there is some reason that I can't save variables to an array this way, but i can't figure out why. I was hoping that if I'm going about this in the wrong way, someone can point me in the right direction.
const int buttonPin = 2;
int x = 0;
int Position1 = 0;
int Position2 = 0;
int Position3 = 0;
int Position4 = 0;
int Position5 = 0;
int allPositions[5] = {
Position1, Position2, Position3, Position4, Position5
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int startPressed = 0; // the time button was pressed
int endPressed = 0; // the time button was released
int timeHold = 0; // the time button is hold
int timeReleased = 0; // the time button is released
char words[10];
char* dotsandDashes[5] = {};
char* letters[] = {
".-", "-...", "-.-.", "-..", ".", "..-.", "--.", "....", "..", // A-I
".---", "-.-", ".-..", "--", "-.", "---", ".--.", "--.-", ".-.", // J-R
"...", "-", "..-", "...-", ".--", "-..-", "-.--", "--.." // S-Z
char* numbers[] = {"-----", ".----", "..---", "...--", "....-", ".....", "-....",
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH);
// initialize serial communication:
int a = Position1 && Position2 && Position3 && Position4 && Position5;
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
if (x < 5) {
// button state changed
if (buttonState != lastButtonState) {
// the button was just pressed
if (buttonState == LOW) {
startPressed = millis();
timeReleased = startPressed - endPressed;
if (timeReleased >= 600) {
Serial.print("^");
if (Position1 == 1)
Serial.print("a");
switch(Position1, Position2, Position3, Position4, Position5){
case 12000: Serial.print("a");
/* allPositions[0]={0};
allPositions[1]={0};
allPositions[2]={0};
allPositions[3]={0};
allPositions[4]={0};
x=0;*/
if (timeReleased >= 1000) {
Serial.println(" ");
x = 0;
// the button was just released
endPressed = millis();
timeHold = endPressed - startPressed;
if (timeHold <= 250 && timeHold > 40) {
Serial.print(".");
allPositions[x] = 1;
x++;
if (timeHold >= 251) {
Serial.print("-");
allPositions[x] = 2;
x++;
}Serial.print(Position1);
Serial.print(Position2);
Serial.print(Position3);
Serial.print(Position4);
Serial.print(Position5);
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState ;
I think the problem is how these definitions...
int Position1 = 0;
int Position2 = 0;
int Position3 = 0;
int Position4 = 0;
int Position5 = 0;
relate to this:
Serial.print(".");
x++;
Serial.print("-");
x++;
and mostly just this:
