Morse code to DMX512 transmitter
Hi All,
I am building a light sculpture that has two parts
the two parts will have (simulated) conversation in morse code by way of flashing lights.
I am using wireless DMX to get the signal to the lights and a DMX shield to get the signal out of Arduino land.
I am using a variant of the excellent morse code code found here on git hub here.
and the conceptikinetics DMX library.
THE PROBLEM:
I have managed to get one channel of DMX to flash the morse code. but i need to alternate the channels to simulate the "conversation" ie:
channel1 (hello)
channel2 (hi)
channel1 (soooo)
and so on ( i promise to think of something more interesting for the sculpture to say!)
a penny for your thoughts!
Please see code attached, the action is near the end where I have made the morse code operate channel 1 in DMX land. ( maybe it is possible to select this channel in the Void loop instead. i have tried a bunch of things but TBH i am not a programmer and its all guesswork and google for me... and hours... and hours....
//THIS IS A SECOND GO AT DOING A ARDUINO CODE THAT
//READS A LINE OF A STORED "CONVERSATION"
//CONVERTS TO MORSE CODE
//SENDS THE MORSE PHRASE TO DMX ADRESS 1
//THEN
//PROGRAM READS THE NEXT LINE
//SENDS THE MORSE PHRASE TO DMX ADRESS 2
// SO LETS GO!!!
//DMX LIBRARY
#include <Conceptinetics.h>
//DMX PIN AND NUMBER OF CHANNELS
#define RXEN_PIN                2
#define DMX_MASTER_CHANNELS   10
// Configure a DMX master controller, the master controller
// will use the RXEN_PIN to control its write operation
// on the bus
DMX_Master        dmx_master ( DMX_MASTER_CHANNELS, RXEN_PIN );
//NOW THE MORSE CODE STUFF
//Define the LED Pin
#define PIN_OUT        13 ///remnant from when it was flashing led
//Define unit length in ms
#define UNIT_LENGTH    200
//Build a struct with the morse code mapping
static const struct {const char letter, *code;} MorseMap[] =
  { 'A', ".-" },
  { 'B', "-..." },
  { 'C', "-.-." },
  { 'D', "-.." },
  { 'E', "." },
  { 'F', "..-." },
  { 'G', "--." },
  { 'H', "...." },
  { 'I', ".." },
  { 'J', ".---" },
  { 'K', "-.-" },
  { 'L', ".-.." },
  { 'M', "--" },
  { 'N', "-." },
  { 'O', "---" },
  { 'P', ".--." },
  { 'Q', "--.-" },
  { 'R', ".-." },
  { 'S', "..." },
  { 'T', "-" },
  { 'U', "..-" },
  { 'V', "...-" },
  { 'W', ".--" },
  { 'X', "-..-" },
  { 'Y', "-.--" },
  { 'Z', "--.." },
  { ' ', "     " }, //Gap between word, seven units
  { '1', ".----" },
  { '2', "..---" },
  { '3', "...--" },
  { '4', "....-" },
  { '5', "....." },
  { '6', "-...." },
  { '7', "--..." },
  { '8', "---.." },
  { '9', "----." },
  { '0', "-----" },
//MORE MORSE CODE STUFF
void doMorse(int pin, const char *string) {
  size_t i, j;
  for( i = 0; string[i]; ++i )
    for( j = 0; j < sizeof MorseMap / sizeof *MorseMap; ++j )
      if( toupper(string[i]) == MorseMap[j].letter )
        emitMorse(pin, MorseMap[j].code);
    emitMorse(pin, "  "); //Add tailing space to separate the chars
// NOW I THINK ITS DOING A SWITCHCASE FOR THE DITS AND DAHS....
void emitMorse(int pin, const char *morseString) {
  for(int i=0; morseString[i]; i++)
    switch( morseString[i] )
    {static int dimmer_val;
//THIS BIT READS THE MORSE AND SENDS TO DMX CHANNEL 1
// THE 100 DOLLAR QUESTION IS HOW CAN SEND EACH LINE OF TEXT TO ALTERNATING  DMX CHANNELS??
// I THINK THIS BIT IS THE PROBLEM_ BY MAKING THE SWITCH CASE DRIVE THE DMX DIRECTLY
//ITS HARD TO CHANGE THE CHANNEL VALUES
case '.': //dit
     dmx_master.setChannelValue ( 1, 255 );
        delay( UNIT_LENGTH );
     dmx_master.setChannelValue ( 1, 0 );
      case '-': //dah
    dmx_master.setChannelValue ( 1, 255);
        delay( UNIT_LENGTH*3 );
      case ' ': //gap
  // Enable DMX master interface and start transmitting
  dmx_master.enable ();
  // Set channel 1 - 10 @ 0%
  dmx_master.setChannelRange ( 1, 10, 000 );
  // NOT SURE IF THIS BIT IS STILL BEING USED
  pinMode( PIN_OUT, OUTPUT );
  digitalWrite( PIN_OUT, LOW );
  delay(1000);                       // wait for a second
  doMorse(PIN_OUT, "HELLO");           //PERSON 1 CHANNEL 1
  doMorse(PIN_OUT, "HOW ARE YOU");   // PERSON 2 CHANNEL 2
  doMorse(PIN_OUT, "GOOD THANK YOU");  //PERSON 1 CHANNEL 1
When you send the strings, change the PIN_OUT to the DMX channel you want
and then replace the fixed DMX channel of 1 with pin
      case '.': //dit
      case '-': //dah
      case ' ': //gap
Legend Riva!
i will give it a go right now!
Problem Solved. Much respect to Riva and my friend Lemming who helped as well
both light are working great now on the tow channels see code below:
declared the DMX_CHAN variable
//set DMX channel
int DMX_CHAN;
swapped out the static DMX channel for the variable
dmx_master.setChannelValue ( DMX_CHAN, 255 );
     dmx_master.setChannelValue ( DMX_CHAN, 0 );
      case '-': //dah
    dmx_master.setChannelValue ( DMX_CHAN, 255);
and then set the DMX_CHAN as required in the void loop
  DMX_CHAN = 1;
    delay(2000);                       // wait for a second
  DMX_CHAN = 4;
    delay(2000);
  DMX_CHAN = 1;
:slight_smile: :slight_smile: :slight_smile: it seems so simple now but if you knew how many hours i tried to work it out myself.........
thanks again.
Glad it works but you have created another variable called DMX_CHAN when you could have just replaced the PIN_OUT parameter with your DMX channel number and adjusted the emitMorse() procedure to use that parameter.
Pretty much the same code as you originally had but have applied the changes I was talking about.
//THEN
// SO LETS GO!!!
//DMX LIBRARY
#define RXEN_PIN               2
// on the bus
  { 'A', ".-" },
  { 'B', "-..." },
  { 'C', "-.-." },
  { 'D', "-.." },
  { 'E', "." },
  { 'F', "..-." },
  { 'G', "--." },
  { 'H', "...." },
  { 'I', ".." },
  { 'J', ".---" },
  { 'K', "-.-" },
  { 'L', ".-.." },
  { 'M', "--" },
  { 'N', "-." },
  { 'O', "---" },
  { 'P', ".--." },
  { 'Q', "--.-" },
  { 'R', ".-." },
  { 'S', "..." },
  { 'T', "-" },
  { 'U', "..-" },
  { 'V', "...-" },
  { 'W', ".--" },
  { 'X', "-..-" },
  { 'Y', "-.--" },
  { 'Z', "--.." },
  { '1', ".----" },
  { '2', "..---" },
  { '3', "...--" },
  { '4', "....-" },
  { '5', "....." },
  { '6', "-...." },
  { '7', "--..." },
  { '8', "---.." },
  { '9', "----." },
  { '0', "-----" },
void doMorse(int dmx_channel, const char *string)
  size_t i, j;
        emitMorse(dmx_channel, MorseMap[j].code);
    emitMorse(dmx_channel, "  "); //Add tailing space to separate the chars
void emitMorse(int dmx_channel, const char *morseString)
      case '.': //dit
      dmx_master.setChannelValue ( dmx_channel, 255 );
      dmx_master.setChannelValue ( dmx_channel, 0 );
      case '-': //dah
      dmx_master.setChannelValue ( dmx_channel, 255);
      case ' ': //gap
  dmx_master.setChannelRange ( 1, 10, 0 );
  doMorse(1, "HELLO");           //PERSON 1 CHANNEL 1
  doMorse(2, "HOW ARE YOU");   // PERSON 2 CHANNEL 2
  doMorse(1, "GOOD THANK YOU");  //PERSON 1 CHANNEL 1
Thats even better Riva!
Thank you, i couldn't quite understand the first time.
That does make sense now.
B.
