morse code
10
11 //Choose the pin that has the LED connected to it
12 const int led = 13;
13
14 //Morse Code Timings - change as desired
15 const double MULTIPLIER = 2.5; //Increase durations of dots/dashes
16 const double DOT = 92.3 * MULTIPLIER; //1 dot
17 const double DASH = 276.9 * MULTIPLIER; //3 dots
18 const double TIMING_SPACE = 92.3 * MULTIPLIER; //1 dot: space between dots/dashes
19 const double CHAR_SPACE = 276.9 * MULTIPLIER; //3 dots: space between characters
20 const double WORD_SPACE = 646.1; //7 dots - space between words
21
22 //Morse Code timings holder array setup
23 const int NUM_CHARS = 96;
24 const int MORSE_MAX_CHAR_SIZE = 7;
25
26 //Array placement is based on a character's ASCII value
27 //IF YOU ADD A NEW VALUE BE SURE TO ADD IT TO THE ACCEPTED CHAR ERROR CHECK
28 //Note: since there is no difference between lower/upper case in Morse,
29 //only upper is entered here - lower case is converted to upper using ASCII
30 int TIMINGS[NUM_CHARS][MORSE_MAX_CHAR_SIZE] = {
31  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
32  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
33  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
34  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
35  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
36  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
37  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
38  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
39  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
40  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
41  {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
42  {DASH, DOT, DASH, DOT, DASH, DASH, 0}, //!
43  {DOT, DASH, DOT, DOT, DASH, DOT, 0}, //"
44  {0, 0, 0, 0, 0, 0, 0},
45  {DOT, DOT, DOT, DASH, DOT, DOT, DASH}, //$
46  {0, 0, 0, 0, 0, 0, 0},
47  {DOT, DASH, DOT, DOT, DOT, 0, 0}, //&
48  {DOT, DASH, DASH, DASH, DASH, DOT, 0}, //'
49  {DASH, DOT, DASH, DASH, DOT, 0, 0}, //(
50  {DASH, DOT, DASH, DASH, DOT, DASH, 0}, //)
51  {0, 0, 0, 0, 0, 0, 0},
52  {DOT, DASH, DOT, DASH, DOT, 0, 0}, //+
53  {DASH, DASH, DOT, DOT, DASH, DASH, 0}, //,
54  {DASH, DOT, DOT, DOT, DOT, DASH, 0}, //-
55  {DOT, DASH, DOT, DASH, DOT, DASH, 0}, //.
56  {DASH, DOT, DOT, DASH, DOT, 0, 0}, ///
57  {DASH, DASH, DASH, DASH, DASH, 0, 0}, //0
58  {DOT, DASH, DASH, DASH, DASH, 0, 0}, //1
59  {DOT, DOT, DASH, DASH, DASH, 0, 0}, //2
60  {DOT, DOT, DOT, DASH, DASH, 0, 0}, //3
61  {DOT, DOT, DOT, DOT, DASH, 0, 0}, //4
62  {DOT, DOT, DOT, DOT, DOT, 0, 0}, //5
63  {DASH, DOT, DOT, DOT, DOT, 0, 0}, //6
64  {DASH, DASH, DOT, DOT, DOT, 0, 0}, //7
65  {DASH, DASH, DASH, DOT, DOT, 0, 0}, //8
66  {DASH, DASH, DASH, DASH, DOT, 0, 0}, //9
67  {DASH, DASH, DASH, DOT, DOT, DOT, 0}, //:
68  {DASH, DOT, DASH, DOT, DASH, DOT, 0}, //;
69  {0, 0, 0, 0, 0, 0, 0},
70  {DASH, DOT, DOT, DOT, DASH, 0, 0}, //=
71  {0, 0, 0, 0, 0, 0, 0},
72  {DOT, DOT, DASH, DASH, DOT, DOT, 0}, //?
73  {DOT, DASH, DASH, DOT, DASH, DOT, 0}, //@
74  {DOT, DASH, 0, 0, 0, 0, 0}, //A
75  {DASH, DOT, DOT, DOT, 0, 0, 0}, //B
76  {DASH, DOT, DASH, DOT, 0, 0, 0}, //C
77  {DASH, DOT, DOT, 0, 0, 0, 0}, //D
78  {DOT, 0, 0, 0, 0, 0, 0}, //E
79  {DOT, DOT, DASH, DOT, 0, 0, 0}, //F
80  {DASH, DASH, DOT, 0, 0, 0, 0}, //G
81  {DOT, DOT, DOT, DOT, 0, 0, 0}, //H
82  {DOT, DOT, 0, 0, 0, 0, 0}, //I
83  {DOT, DASH, DASH, DASH, 0, 0, 0}, //J
84  {DASH, DOT, DASH, 0, 0, 0, 0}, //K
85  {DOT, DASH, DOT, DOT, 0, 0, 0}, //L
86  {DASH, DASH, 0, 0, 0, 0, 0}, //M
87  {DASH, DOT, 0, 0, 0, 0, 0}, //N
88  {DASH, DASH, DASH, 0, 0, 0, 0}, //O
89  {DOT, DASH, DASH, DOT, 0, 0, 0}, //P
90  {DASH, DASH, DOT, DASH, 0, 0, 0}, //Q
91  {DOT, DASH, DOT, 0, 0, 0, 0}, //R
92  {DOT, DOT, DOT, 0, 0, 0, 0}, //S
93  {DASH, 0, 0, 0, 0, 0, 0}, //T
94  {DOT, DOT, DASH, 0, 0, 0, 0}, //U
95  {DOT, DOT, DOT, DASH, 0, 0, 0}, //V
96  {DOT, DASH, DASH, 0, 0, 0, 0}, //W
97  {DASH, DOT, DOT, DASH, 0, 0, 0}, //X
98  {DASH, DOT, DASH, DASH, 0, 0, 0}, //Y
99  {DASH, DASH, DOT, DOT, 0, 0, 0}, //Z
100   {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0},
101   {0, 0, 0, 0, 0, 0, 0},
102   {DOT, DOT, DASH, DASH, DOT, DASH, 0}, //_
103 };
104
105 //The setup routine runs once when you press reset:
106 void setup() {
107   //Initialize the digital pin as an output
108   pinMode(led, OUTPUT);
109
110   //Initialize Serial
111   Serial.begin(9600);
112 }
113
114 //Basic linked-list node implementation
115 struct node {
116   char value;
117   struct node *next;
118 };
119
120 //The loop routine runs in an infinite loop:
121 void loop() {
122   //Ask the user for the string
123   Serial.println("Send text to be displayed in Morse Code");
124
125   //Wait until the user has entered data
126   while(Serial.available() == 0);
127
128   //Give Serial a chance to read all the bytes
129   delay(100);
130
131   //Setup the list
132   struct node *root, *currentNode;
133   root = (struct node*)malloc(sizeof(struct node));
134   root->value = '\0';
135   root->next = 0;
136   currentNode = root;
137
138   //Read the user input
139   while(Serial.available() > 0) {
140     currentNode->next = (struct node*)malloc(sizeof(struct node));
141     currentNode = currentNode->next;
142     currentNode->value = Serial.read();
143     currentNode->next = 0;
144   }
145   currentNode = root;
146
147   //Display the user input back to the user
148   Serial.println("Displaying: ");
149   while(currentNode->next != 0) {
150     currentNode = currentNode->next;
151     Serial.print(currentNode->value);
152   }
153   Serial.println();
154   currentNode = root;
155
156   //Go through all  nodes and display characters in Morse Code via the LED
157   while(currentNode->next != 0) {
158     //Move to the next character
159     currentNode = currentNode->next;
160
161     //Get the ASCII value of the character being looked at
162     int ASCII = currentNode->value;
163
164     //Convert lower case letters to upper case
165     if(ASCII >= 97 && ASCII <= 122) {
166       ASCII = ASCII - 32;
167     }
168
169     //Ensure the character is one that has been programmed in for Morse
170     if((ASCII >= 32 && ASCII <= 34) || ASCII == 36 ||
171        (ASCII >= 38 && ASCII <= 41) || (ASCII >= 43 && ASCII <= 59) ||
172        ASCII == 61 || (ASCII >= 63 && ASCII <= 90) || ASCII == 95) {
173       //If the character is a space
174       if(ASCII == 32) {
175         delay(WORD_SPACE);
176       } else {
177         //Go through the timing sequence for each character
178         for(int i = 0; i < MORSE_MAX_CHAR_SIZE; ++i) {
179           //If the timing sequence is over, break the loop
180           if(TIMINGS[ASCII][i] == 0) {
181             break;
182           } else { //Display the timing sequence on the LED
183             digitalWrite(led, HIGH);
184             delay(TIMINGS[ASCII][i]);
185             digitalWrite(led, LOW);
186             delay(TIMING_SPACE);
187           }
188         }
189       }
190     } else {
191       Serial.print("'");
192       Serial.print(currentNode->value);
193       Serial.print("' does not have a Morse Code timing. Skipping it.");
194       Serial.println();
195     }
196     delay(CHAR_SPACE);
197   }
198 }
the above code I would like to know if any body can make it work with more than 1 led max 8 each flashing the next letter In the sequence
Yes, but we won't. Try it yourself and when there is a problem a google search doesn't solve, ask.
lg, couka
I am trying to , but I am struggling ,
this is why I asked for help
No, you're not asking for help, your asking for someone to do this for you.
Tell us what you tried and what doesn't work.
lg, couka
I duplicated this line
13 const int led = 9;
const int led = 13;
I have also tried const int led = 9,13;
You can't have two entities with the same name in the same scope - how would you know which one to address?
Please omit the line numbers when posting code.
sorry about line numbers, as you can see I am a beginner , I am trying ,
const int led =  9;
  //Initialize Serial
struct node {
  char value;
  struct node *next;
  while (Serial.available() == 0);
  delay(100);
  //Setup the list
  root->value = '\0';
  root->next = 0;
  currentNode = root;
  while (Serial.available() > 0) {
  currentNode = root;
  while (currentNode->next != 0) {
  currentNode = root;
    if (ASCII >= 97 && ASCII <= 122) {
      ASCII = ASCII - 32;
    if ((ASCII >= 32 && ASCII <= 34) || ASCII == 36 ||
      if (ASCII == 32) {
        delay(WORD_SPACE);
        for (int i = 0; i < MORSE_MAX_CHAR_SIZE; ++i) {
          if (TIMINGS[ASCII][i] == 0) {
      Serial.print("'");
    delay(CHAR_SPACE);
Your TIMINGS array is a huge waste of precious RAM.
I might be inclined to write a class to drive a single LED with a single given letter, and then have an array of objects of that class.
what did you say told you I was a beginner
