morse function not working
hey guys I need a little help, I have a set of code that functions as it should do except the morse isn’t functioning.
when compiling I get no errors, I’ve tested the circuit and power/communication isn’t the problem, its either the pin im using isn’t compatible with the code or somethings wrong in the lines of code.
firstly, the libraries are in documents>Arduino>libraries and the file titles match. the other library in the code is also in documents>Arduino>libraries and functions perfectly.
I tried swapping the pin allocations and had no luck with that. the circuit board is already assembled and im using an ATTINY85
heres the code
//Spitfire_Mk5b_Revision_2.9.0_With_Morse_Code
#define PIN_STATUS 4
#include <LedFlasher.h>
#include <morse.h>
LEDMorseSender sender(PIN_STATUS);
const byte WTPin = 0;
const byte muzzlesPin = 3;
LedFlasher muzzles     (muzzlesPin,    100,       15,     false);
typedef enum
  initialState,
  wantGunFlashOFF,
  wantGunFlashON,
  wantCockpit,
states;
states state = initialState;
unsigned long lastStateChange = 0;
unsigned long timeInThisState = 5;
void setup ()
  pinMode (WTPin, OUTPUT);
  pinMode (muzzlesPin, OUTPUT);
  sender.setup();
  sender.setMessage(String("dear jay i hope you like your present from matthew"));
  muzzles.begin();
void doStateChange ()
  lastStateChange = millis ();
  switch (state)
    case initialState:
         state = wantCockpit;
    case wantCockpit:
         sender.startSending();
         digitalWrite (WTPin, HIGH);
         state = wantGunFlashON;
    case wantGunFlashON:
         muzzles.on();
         state = wantGunFlashOFF;
         timeInThisState = random(500,1500);
    case wantGunFlashOFF:
         muzzles.off();
         timeInThisState = random(2000, 15000);
void loop ()
   if (millis () - lastStateChange >= timeInThisState)
     doStateChange ();
   muzzles.update ();
   if (!sender.continueSending())
can anyone see any reason the line of morse code isn’t functioning?
I read your post several times and never found an explanation of what is actually wrong. How, exactly, do your expectations for the program behaviour differ from your observations?
hey guys I need a little help, I have a set of code that functions as it should do except the morse isn't functioning.
the morse isn't working.....its meant to display morse code on an led but the morse coding isn't working......
Define, "isn't working". Describe it.
the led does nothing, no readout on the pin with a multimeter.
I've reallocated the other functions (i.e WTpin and muzzlespin) to the morse pin to check that, and the circuitry is fine as the led works when other functions allocated to the correct led.
but no matter that pin the morse is allocated to, the morse coding doesn't seem to be starting up. which makes me think the coding is the issue?
You never set the pin mode for PIN_STATUS. That's no good, unless the morse library does that for you.
honestly not sure if it does or not. heres the files
morse.h
#pragma once
 * Generate and send Morse Code on an LED or a speaker. Allow sending
 * in a non-blocking manner (by calling a 'continue sending' method
 * every so often to turn an LED on/off, or to call tone/noTone appropriately).
 * All input should be lowercase. Prosigns (SK, KN, etc) have special
 * character values #defined.
 * See also:
 * Morse decoder (using binary tree):
 * http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1289074596/15
 * Generator (on playground):
 * http://www.arduino.cc/playground/Code/Morse
// for malloc and free, for the new/delete operators
#include <stdlib.h>
// Arduino language types
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#define WPM_DEFAULT 12.0
// PARIS WPM measurement: 50; CODEX WPM measurement: 60 (Wikipedia:Morse_code)
#define DITS_PER_WORD 50
// Pass to SpeakerMorseSender as carrierFrequency to suppress the carrier.
#define CARRIER_FREQUENCY_NONE 0
// Bitmasks are 1 for dah and 0 for dit, in left-to-right order;
// the sequence proper begins after the first 1 (a sentinel).
// Credit for this scheme to Mark VandeWettering K6HX ( brainwagon.org ).
typedef unsigned int             morseTiming_t;
typedef unsigned char morseBitmask_t; // see also MAX_TIMINGS
#define MORSE_BITMASK_HIGH_BIT B10000000
// sentinel
#define END             0
// the most timing numbers any unit will need; ex: k = on,off,on,off,on,end = 5
#define MAX_TIMINGS     15
// Punctuation and Prosigns
#define PROSIGN_SK 'S'
#define PROSIGN_KN 'K'
#define PROSIGN_BT 'B'
typedef struct {
 char c;
 morseBitmask_t timing;
} specialTiming;
const specialTiming MORSE_PUNCT_ETC[] = {
 {'.', B1010101},
 {'?', B1001100},
 {PROSIGN_SK, B1000101},
 {PROSIGN_KN, B110110},
 {PROSIGN_BT, B110001},
 {END, B1},
// Morse Code (explicit declaration of letter timings)
const morseBitmask_t MORSE_LETTERS[26] = {
 /* a */ B101,
 /* b */ B11000,
 /* c */ B11010,
 /* d */ B1100,
 /* e */ B10,
 /* f */ B10010,
 /* g */ B1110,
 /* h */ B10000,
 /* i */ B100,
 /* j */ B10111,
 /* k */ B1101,
 /* l */ B10100,
 /* m */ B111,
 /* n */ B110,
 /* o */ B1111,
 /* p */ B10110,
 /* q */ B11101,
 /* r */ B1010,
 /* s */ B1000,
 /* t */ B11,
 /* u */ B1001,
 /* v */ B10001,
 /* w */ B1011,
 /* x */ B11001,
 /* y */ B11011,
 /* z */ B11100,
 * Define the logic of converting characters to on/off timing,
 * and encapsulate the state of one sending-in-progress Morse message.
 * Subclasses define setOn and setOff for (for example) LED and speaker output.
class MorseSender {
protected:
 const unsigned int pin;
 // The setOn and setOff methods would be pure virtual,
 // but that has compiler issues.
 // See: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1167672075 .
 * Called to set put the output in 'on' state, during a dit or dah.
 virtual void setOn();
 virtual void setOff();
 * Called before sending a message. Used for example to enable a
 * carrier. (Noop in the base class.)
 virtual void setReady();
 virtual void setComplete();
private:
 morseTiming_t DIT, DAH;
 String message;
 // on,off,...,wait,0 list, millis
 morseTiming_t timingBuffer[MAX_TIMINGS+1];
 // index of the character currently being sent
 unsigned int messageIndex;
 // timing unit currently being sent
 unsigned int timingIndex;
 // when this timing unit was started
 unsigned long lastChangedMillis;
 * Copy definition timings (on only) to raw timings (on/off).
 * @return the number of 'on' timings copied
 int copyTimings(morseTiming_t *rawOut,
 morseBitmask_t definition);
 * Fill a buffer with on,off,..,END timings (millis)
 * @return the index at which to start within the new timing sequence
 unsigned int fillTimings(char c);
public:
 * Create a sender which will output to the given pin.
 MorseSender(unsigned int outputPin, float wpm=WPM_DEFAULT);
 * To be called during the Arduino setup(); set the pin as OUTPUT.
 void setup();
 * Set the words per minute (based on PARIS timing).
 void setWPM(float wpm);
 * Set the duration, in milliseconds, of a DIT.
 void setSpeed(morseTiming_t duration);
 * Set the message to be sent.
 * This halts any sending in progress.
 void setMessage(const String newMessage);
 * Send the entirety of the current message before returning. See the "simple"
 * example, which uses sendBlocking to send one message.
 void sendBlocking();
 * Prepare to send and begin sending the current message. After calling this,
 * call continueSending repeatedly until it returns false to finish sending
 * the message. See the "speeds" example, which calls startSending and
 * continueSending on two different senders.
 void startSending();
 * Switch outputs on and off (and refill the internal timing buffer)
 * as necessary to continue with the sending of the current message.
 * This should be called every few milliseconds (at a significantly
 * smaller interval than a DIT) to produce a legible fist.
 * @see startSending, which must be called first
 * @return false if sending is complete, otherwise true (keep sending)
 boolean continueSending();
 void *operator new(size_t size);
 void operator delete(void* ptr);
 * Adapt Morse sending to use the Arduino language tone() and noTone()
 * functions, for use with a speaker.
 * If a carrierFrequency is given, instead of calling noTone, call tone
 * with a low frequency. This is useful ex. for maintaining radio links.
class SpeakerMorseSender: public MorseSender {
 private:
 unsigned int frequency;
 unsigned int carrFrequency;
 protected:
 public:
 // concert A = 440
 // middle C = 261.626; higher octaves = 523.251, 1046.502
 SpeakerMorseSender(
 int outputPin,
 unsigned int toneFrequency=1046,
 unsigned int carrierFrequency=CARRIER_FREQUENCY_NONE,
 * Sends Morse on a digital output pin.
class LEDMorseSender: public MorseSender {
 private:
 bool activeLow;
 protected:
 public:
 * Creates a LED Morse code sender with the given GPIO pin.  The optional
 * boolean activeLow indicates LED is ON with digital LOW value.
 * @param outputPin GPIO pin number
 * @param activeLow set to true to indicate the LED ON with digital LOW value.  default: false
 * @param wpm words per minute, default: WPM_DEFAULT
 LEDMorseSender(int outputPin, bool activeLow = false, float wpm=WPM_DEFAULT);
 * Creates a LED Morse code sender with the given GPIO pin.  This constructor is for backward compability.
 LEDMorseSender(int outputPin, float wpm);
 * Sends Morse on an analog output pin (using PWM). The brightness value is
 * between 0 and 255 and is passed directly to analogWrite.
class PWMMorseSender: public MorseSender {
 private:
 byte brightness;
 protected:
 public:
 PWMMorseSender(int outputPin, float wpm=WPM_DEFAULT, byte brightness=255);
 void setBrightness(byte brightness);
if it needs setting can you advise as don’t recall needing to do it on a lost project
not going to lie I barely scrapped through last time I used it and got it working so the helps appreciated
OK so I believe the pinmode is set within the library, for whatever reason, the morse isn't "activating" and cant work out why.
secretreeve:
OK so I believe the pinmode is set within the library, for whatever reason, the morse isn’t “activating” and cant work out why.
Your belief is wrong. There is no pinMode() in there. So try setting it in your program.
Steve
hi slip, I did try adding pinMode (PIN_STATUS, OUTPUT); into void setup section but made no difference
From morse.cpp
void MorseSender::setup() { pinMode(pin, OUTPUT); }
[/quote]
evanmars:
From morse.cpp
ok so its it setup by the morse.ccp or not cause now im confused lol
