morse transceiver system
Hi there,
So I'm kinda new to Arduino and C, and have been trying to create a transceiver device that takes button inputs as morse dots and dashes, and sends them over 433MHz, where it's translated and printed on the lcd screen.
The issue i have is that after installing the nRF905, i ran out of pins and decided to take up an I/o expander shield running on the mcp23017. So far i've tried my best, but just am not very good at this.
My code is as follows
#include <LiquidCrystal.h>
#include <RadioHead.h>
#include <RH_NRF905.h>
#include <RH_Serial.h>
#include <Arduino.h>
#include <string.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <Adafruit_MCP23017.h>
Adafruit_MCP23017 mcp;
const int
rs = 8,
en = 11,
d4 = 5,
d5 = 4,
d6 = 3,
d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int contrast = 75;
String morse;
int sizeOf = morse.length();
String morse1;
uint8_t buf[RH_NRF905_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
// constants won't change. They're used here to set pin numbers:
const int buttonPinShort = A0;
const int buttonPinLong = A1;
const int buttonPinSend = A3;
const int buttonPinSpace = A2;// the number of the pushbutton pin
const int ledPin = 5;      // the number of the LED pin
const int buzzer = 7;
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
// Variables will change:
int ledState = HIGH;
String text = "";
int characterAscii = 0;
int startPos = 0, endPos = 0;
int startPos1 = 0, endPos1 = 0;
String characterCode = "";
int buttonStateLong = 0;
int buttonStateShort = 0;
int buttonStateSpace = 0;
int buttonStateSend = 0;
int lastButtonStateShort = LOW;   // the previous reading from the input pin
int lastButtonStateLong = LOW;
int lastButtonStateSpace = LOW;
int lastButtonStateSend = LOW;
char p[150];
using namespace std;
// Singleton instance of the radio driver
RH_NRF905 nrf905;
 mcp.begin();
  morse = "";
  while (!Serial)
    ; // wait for serial port to connect.
  if (!nrf905.init())
    Serial.println("init failed");
  // Defaults after init are 433.2 MHz (channel 108), -10dBm
  pinMode(buttonPinShort, INPUT); //set up for buttons
  pinMode(buttonPinLong, INPUT);
  pinMode(buttonPinSpace, INPUT);
  pinMode(buttonPinSend, INPUT);
  pinMode(ledPin, OUTPUT);
  // set initial LED state
  digitalWrite(ledPin, ledState);
  digitalWrite(6, contrast);
  lcd.begin(16, 2);
  lcd.setCursor(0, 15);
  // read the state of the switch into a local variable:
  int readingShort = digitalRead(buttonPinShort);
  int readingLong = digitalRead(buttonPinLong);
  int readingSpace = digitalRead(buttonPinSpace);
  int readingSend = digitalRead(buttonPinSend);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH), and you've waited long enough
  // since the last press to ignore any noise:
  if (buttonStateShort == HIGH) {
    ledState = HIGH;
  if (buttonStateLong == HIGH) {
    ledState = HIGH;
  else ledState = LOW;
  // If the switch changed, due to noise or pressing:
  if (readingShort != lastButtonStateShort) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if (readingLong != lastButtonStateLong) {
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer than the debounce
    // delay, so take it as the actual current state:
    if (readingShort != buttonStateShort) {
      buttonStateShort = readingShort;
      // only toggle the LED if the new button state is HIGH
        morse = morse += ".";
      } // press for a dot
    if (readingLong != buttonStateLong) {
      buttonStateLong = readingLong;
        morse = morse += "-";
      } // press for a dash
    if (readingSpace != buttonStateSpace) {
      buttonStateSpace = readingSpace;
      if (buttonStateSpace == HIGH) {
        morse = morse += " ";
      } // press for a space between letters
      // press 3 times between words
    if (readingSend != buttonStateSend) {
      buttonStateSend = readingSend;
      if (buttonStateSend == HIGH) {
        lcd.println(morse);
        Serial.println("Sending to nrf905_server");
        morse.toCharArray(p, sizeOf);
        uint8_t data[sizeof(p)] = {p};
        nrf905.send(data, sizeof(p));
        Serial.println(morse);
        nrf905.waitPacketSent();
         if (nrf905.waitAvailableTimeout(500))
  { Serial.println("waitavTimeout");
    // Should be a reply message for us now
    if (nrf905.recv(buf, &len))
    { Serial.println("recv buffer");
      morse1 = (char*)buf;
      morse1.replace(" .- ", "a ");
      morse1.replace(" -... ", "b ");
      morse1.replace(" -.-. ", "c ");
      morse1.replace(" -.. ", "d ");
      morse1.replace(" . ", "e ");
      morse1.replace(" ..-. ", "f ");
      morse1.replace(" --. ", "g ");
      morse1.replace(" .... ", "h ");
      morse1.replace(" .. ", "i ");
      morse1.replace(" .--- ", "j ");
      morse1.replace(" -.- ", "k ");
      morse1.replace(" .-.. ", "l ");
      morse1.replace(" -- ", "m ");
      morse1.replace(" -. ", "n ");
      morse1.replace(" --- ", "o ");
      morse1.replace(" .--. ", "p ");
      morse1.replace(" --.- ", "q ");
      morse1.replace(" .-. ", "r ");
      morse1.replace(" ... ", "s ");
      morse1.replace(" - ", "t ");
      morse1.replace(" -.. ", "u ");
      morse1.replace(" ...- ", "v ");
      morse1.replace(" .-- ", "w ");
      morse1.replace(" -..- ", "x ");
      morse1.replace(" -.-- ", "y ");
      morse1.replace(" --.. ", "z ");
      morse1.replace(" .---- ", "1 ");
      morse1.replace(" ..--- ", "2 ");
      morse1.replace(" ...-- ", "3 ");
      morse1.replace(" ....- ", "4 ");
      morse1.replace(" ..... ", "5 ");
      morse1.replace(" ....- ", "6 ");
      morse1.replace(" ...-- ", "7 ");
      morse1.replace(" ..--- ", "8 ");
      morse1.replace(" .---- ", "9 ");
      morse1.replace(" ----- ", "0 ");
      morse1.replace("   ", "  ");
      Serial.println(morse1);
      lcd.print(morse1);
      for (int positionCounter = 0; positionCounter < 13; positionCounter++) {
        // scroll one position left:
        lcd.scrollDisplayLeft();
        // wait a bit:
        // scroll 29 positions (string length + display length) to the right
        // to move it offscreen right:
        for (int positionCounter = 0; positionCounter < 29; positionCounter++) {
          // scroll one position right:
          lcd.scrollDisplayRight();
          // wait a bit:
          delay(200);
          lcd.clear();
    if (ledState == HIGH) {
      tone(buzzer, 3423);
    else noTone(buzzer) ;
    // set the LED:
    // save the reading. Next time through the loop, it'll be the lastButtonState:
    lastButtonStateShort = readingShort;
    lastButtonStateLong = readingLong;
    lastButtonStateSpace = readingSpace;
  delay(400);
But it isn't working. The lcd doesn't turn on and the 'send' button doesn't call for the array to be properly sent through the rf module...
I'm trying to use this for a school project, but clearly haven't been successful.
Is anyone able to guide me in the right direction, how to fix the lcd problem, the sending issue.
I also dont get any sound when I press the '-' and '.' buttons.
Thanks!
Why all the posts on the same subject? And at what point in your program development did the problems appear? Undo the last change and see if they work again.
Paul
You don't appear to have anything connected to that mcp23017. Or if you do, you're not using it.
I can't seem to figure how to connect to the mcp23017 and run the LCD on it... I've read online, but I dont understand how to apply it to the lcd display--it is a reg 16x2.
Thanks,
Fadi
Get each individual piece of the project working before putting it all together.
To reduce pin usage with an LCD text display, use an I2C version instead. Interfacing the MCP23017 is an advanced project.
Is it possible to connect a normal lcd via I2C? If so, would you know how to declare the connections at the start?
No.Buy an LCD with an I2C interface.
jremington:
Why no?
The LCD display can not be connected to I2C by itself, you need some kind of backpack. Of course you can try and recreate one yourself, but it's so much easier to just buy the ready made module and solder it onto your LCD display. Or even easier: buy the LCD display with I2C backpack in place.
The more common I2C backpacks are based on the cheaper PCF8574 port extender. I normally buy the 1602 LCD with backpack in pace for about USD 1.5 equivalent a set, a little more for the 2004.
