A voltage divider would work right? From the gate 1k to ground and 1k to my input should be good, unless I need something lower to make it faster?
Grumpy_Mike:
you might need the gate-source resistors as low as 100 ohms (which would mean using 2W resistors!)
A 2W resistor to switch a 10nF capacitor, that sounds a bit excessive. It is not a continuous current rating we are working with.
But if the switching time is otherwise 100us and you're sending a 4.5kHz square wave to it, the FETs will be in linear mode the whole time again and possibly dissipating a lot more than 2W. Certainly 10k gate-pull-down is not really compatible with PWM at kHz rates
BTW all we know so far is that the FETs are getting 4.5kHz and running off 12V - have no idea what the load is, would be nice to know.
It does seem to me that a 1/2 H-bridge MOSFET driver chip is going to solve these problems (do many of them support n+p channel though?)
winner10920:
You don't need a divider if you have a single 12V supply - the motor switching circuit you reference is for split +/-12V supplies, hence the divider to the lower FET's gate. You do need to ensure both FETs cannot be on at the same time though.
The load is basically homemade high frequency transformers, its all just for playing around and maybe learning a bit
But im expecting like 1-3 amps draw but it will probably vary alot, its being fed by a +/-12v supply I made
id also like to be cheap and make this with what I got already, an irf9520 and an irf540
I've never worked with pchannel mosfets or negative voltages before so this part is new to me,
Also the input will be square wave and the frequency will probably be as high as 500khz max more likely in the 1k-200k range
Instead of a +/- 12v supply and mosfet half bridge, have you considered using a single 12v supply and a full bridge?
Making a home-made H-bridge capable of working at high frequencies is not easy. I think you would be better off getting a chip that does it all for you, such as http://www.farnell.com/datasheets/1383760.pdf.
It would definetly be easier but I like the challenge, and the lack of funds kinda supports to use what you got method
But so do u think the 1k divider will work? Where could I find the formula that could tell me my max switching speed?
The main constraint on the mosfet switching time is charging and discharging the gate. The mosfet datasheet usually gives a figure for total gate charge. This value varies with the drain voltage you are switching (the higher the voltage, the higher the total gate charge). To estimate the switching time, use the figure on the datasheet. The time taken to switch the gate is the total gate charge divided by gate drive current. The gate drive current is the excess gate drive voltage divided by the series resistor. The excess gate drive voltage depends on the mosfet and the driving voltage, but for a rough estimate you could assume one third of the gate drive voltage.
Example: 5V Arduino driving a STP40NF10L (total gate charge 46nC typical, when switching 80V @ 40A) through a 220 ohm series resistor:
t = 46nC * 220ohms / (5V / 3) = 6072ns
So you can see that for fast switching, you need to drive the gate from a low resistance source, which is what mosfet driver chips are for.
That goes by gate threshold voltage I guess? Or the 10v they usually spec it at?
The gate voltage plateaus somewhat above the threshold voltage as the gate charges/discharges. A typical non-logic level MOSFET will have a plateau about one third of the 10V gate-fully-on voltage, about 3 or 4V. The exact voltage of the plateau varies with device and drain current and voltage though.
Notice that driving through a resistor means that as the plateau is closer to 0V than 10V, it will discharge more slowly than charging (if plateau at 3V, then there is 7V across resistor when charging, -3V across the resistor when discharging, over twice as slow to switch off.
For this reason you'll see MOSFET driver chips usually provide more current sink than source since they want to correct this imbalance of switching times. My favorite MOSFET driver is probably the MIC4422 which can source or sink upto 9A, Yes, 9A... It makes it a handy MOSFET half-H-bridge in its own right (in fact I've used it as a class-D audio amplifier output stage!).
Wow that's pretty nice, how fast can that switch?
