So I was following a guide for an airsoft mosfet that I am making, and I finished building it but now the Arduino gets power but I guess it can't read the trigger. I know the trigger works, but for some reason my arduino can't read it. Can anyone help me? I am using this guide:
// AirsoftTech.dk
//////// WIRE PIN AN COMPONENT LAYOUT /////////
int MOSFET_PIN = 5; // The Digital pin that attaches to the MOSFET gate, to turn it on and off.
int TRIGGER_PIN = A0; // The analog pin that attaches to the trigger pin
float R1 = 100; // 100Kohm // The Voltage devider resistor R1
float R2 = 10; // 100Kohm // The Voltage devider resistor R2
//////// CONFIG VALUES /////////
int Max_ON_Time = 200; // The time in MS for a full burst cycle...
//////// INTERNAL VALUES /////////
int TrigerStatus = LOW; // The state of the trigger LOW => Not pressed, HIGH => Pressed
int TriggerReadValue = 0; // The value read from the analog trigger pin. => 0-1024
int CurrentSleepTime = 0; // The ammount of time the mosfet has been on.
// The setup routine runs once when you press reset.
// Initialize the digital pin as an output.
pinMode(13, OUTPUT); // LED pin
pinMode(MOSFET_PIN, OUTPUT); // Set the Mosfet pin as an output so that we can send power to the mosfet.
digitalWrite(MOSFET_PIN, LOW); // Make sure we start with power OFF!
digitalWrite(13, LOW); // Make sure we start with power OFF!
// The loop routine runs over and over again forever.
ReadTrigger(); // Update the trigger state
if(TrigerStatus == HIGH) // If the trigger is pushed.
SetMosfet(HIGH); // First turn the Mosfet On
while (TrigerStatus == HIGH)
if(CurrentSleepTime < Max_ON_Time){ // If we have not completed a cycle
CurrentSleepTime = CurrentSleepTime + 1; // Leave the mosfet on, and increase time counter.
SetMosfet(LOW); // If a full cycle has gone, turn the Monfet Off.
delay(1); // Sleep for one milisecond
ReadTrigger(); // Update the trigger status (We stay in the loop untill the trigger is released)
SetMosfet(LOW); // Make sure the Mosfet is off when the trigger is released
CurrentSleepTime = 0; // Reset time counter when the trigger is released.
// This function updates the trigger status when it's called.
void ReadTrigger()
int TriggerReadValue = analogRead(TRIGGER_PIN);
TrigerStatus = LOW;
if(TriggerReadValue > 20) {
TrigerStatus = HIGH;
// This function set the Mosfet state
void SetMosfet(int val)
digitalWrite(13, val); // turn the LED on / off to indicate what the mosfet should be dooing
digitalWrite(MOSFET_PIN, val); // turn the Monfet on / off
I'm kind of pulling my hair out at this point and would appreciate any help I can get. Thanks!
See which value is being read by the analog pin with the trigger activated and without the trigger activated.
// AirsoftTech.dk
void ReadTrigger()
Serial.println(TriggerReadValue);
TrigerStatus = LOW;
Getting a lot of zeros, how would I go about fixing this? I have a voltmeter btw so I can use that if I have to...
Edit: It looks like when using the voltmeter, I have 11.3 volts going through when the trigger isn't pulled, and 0 when it's not. However, after it gets past the 10k resistor and gets to the pin itself, it reads at 11.4 when not pulled and drops to 11.2 when pulled. I think it's an issue with the soldering/wiring but I have no idea what...
Here's what I was trying to make:
I think its from the grey point right below the second red arrow that's connected to d5 though, I think the diagram on the right is correct and the one on the left is just an overview
It might be best just to completely resolder and rewire the trigger to a normal 5v connection instead of using resistors and stuff, I might try that later unless you can find out what I did wrong
