I am trying to bring rectified 110 volts AC down to 90 volts. Rectified 110 rms actually reaches about 155 volts, so I am operating
(on a half wave) anywhere from 0 volts to 155 volts. I have a circuit which, in simulation, does a respectable job of smoothing this and providing 90 volts with maybe +/- 3 volts ripple. In addition, I want to deliver up to 4 amps to my load.
That means this MOSFET is handling a lot of power, and power makes heat. So I find that there are graphs of Safe Operating Areas (SOA) for MOSFETs, and they seem to be premised on pulsed performance. I am doing pulsed performance here, but its a very long pulse (50% duty cycle, 60 Hz.). I don't find anything applicable in these SOA specs, so I am hoping some MOSFET guru out there can tell me whether I am setting myself up for melted MOSFET's, or can this be done with proper heat sinking?
jrdoner:
Normally the graphs show SOA at various pulse lengths and DC. You'll find the
curves are simply current, voltage and power limited (with the power limit
depending on pulse width / duty cycle.
You normally wouldn't go anywhere near the current limit.
Plot your system voltage on the I=0 axis, plot your max current on the V= 0
axis, both points should be inside the DC SOA. Draw a straight line between
them (for a resistive load), and check that if the line strays outside the DC
SOA the shortest pulse time involved. Ensure you switch the device faster
than that (in practice not a problem).
With a high voltage MOSFET you'll find the on-resistance is quite high and the
dissipation may be dominated by this. Note that the edge of the SOA, where it
represents a power limit, assumes you have infinite heatsinking (which you
don't), so derate accordingly.
If you are PWM'ing you will have to calculate switching losses carefully.
BTW If I was handling voltages this high I would definitely use a MOSFET driver
chip to control the gate voltage against dV/dt from the drain. Better still use an
IGBT which are much more robust for high voltage.
