MOSFET saturation question
After learning that power NPN transistors often require much more current than a typical microcontroller can provide to switch large loads, I'm now looking at MOSFETs. Based on my reading, MOSFETs' saturation is based on voltage supplied to the gate as opposed to current. So in order to fully saturate a MOSFET, the gate voltage should be higher than the max gate threshold voltage.
For the following MOSFET http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00240517.pdf it lists a max gate threshold voltage of 2.5 volts, so the 5 volt output of an Arduino pin should be more than enough voltage to saturate the MOSFET if I understand correctly.
The gate-source voltage is 20V not 2.5V. Also how much current are you planning to go from drain to source?
No the gate threshold is the point where the FET just starts to turn on. What you need to look at is the voltage quoted when the resistance from drain to source is quoted. That is the voltage you need to supply to the gate.
Grumpy_Mike:
Ok thanks, I see 4.5 volts and 10 volts listed with a drain current of 37.5 amps (with lower resistance at 10 volts), so could I get away with using 5 volts?
For that specific chip as long as that on resistance is sutiable then yes you can use 5 V.
Great, thanks for the help.
Also mind the input capacitance (gate-source) of this transistor is 1.7nF. So based on what current you want switch and how fast, you should consider that (it creates heat).
You are mistaken about the 37.5 amps : that is the Diode current when -1 volt is the drain source voltage. That is not for normal operations that is for a fault condition when the wrong voltage sets the source higher than the drain voltage.
I read the datasheet STD75N3H6 and here is what you need to know for correct operation
Yes, 5 volts from gate to source will turn on the MOSFET.
30 volts can be applied to the drain, but not while drawing a high current. The Arduino can put 5 volts on the gate. That 30 volts will not be connected to the Arduino through a wire, a capacitor blocks that 30 volts from reaching from drain to gate. It is the built in gate capacitance that insulates the Arduino from the 30 volt load on the MOSFET drain.
The STD75N3H6 can handle 60 watts. P is power The STD75N3H6 can carry 75 amps (I), but the drain voltage will only be a voltage (V) 0.8 volts because:
P=IV
V =P/I = 60 watts/75 amps = 0.8 volts drain to source voltage
When V = 30 volts , P=VI = 60w = 30 volts x 2 Amps
In Figure 4 of the STD75N3H6 datasheet is shown the current when you put 5 volts on the gate : 200 Amps can be drawn during a short pulse, but continuous operation at this level would melt the wires inside the STD75N3H6 . Please limit the power to 60 watts and use a heat sink at that power level.
Here is a summary of what Figure 4 says in a graph : VGS gate voltage from Arduino at 5 volts
VDS IDS POWER .5 v 80 amps 40Watt using continuous current 1.0v 130 amps 130Watt when current is pulsed to keep average power less than 60 watts
