MOSFET Stepper Motor driver Odd Problem
Hi All
I have a confusing one. I dont have any diagrams to show atm, but basicly;
I have 4 MOSFET's being controlled from 4 digital pins from an arduino UNO, which ground the connected wire from a 6 wire stepper motor.
The problem i'm having is when i run my code, which sets one of the pins HIGH and the other 3 LOW then has a delay of about 100ms, then repeats with the next pin HIGH and others LOW, only 3 out of the 4 mosfets seem to switch on.
I have tried changing arduinos, changing output pins, mosfets, stepper motors which no luck.
I know i have not put any diagrams or any specs but i dont have any atm but any pearls of wisdom would be apperciated
or any code...
Here is my code. I have swapped out the 4 mosfets with a darlington array chip that has no trouble working but isnt rated to the stepper motors current, hence the reason for using mosfets.
int motorPin1 = 10; //Brown
int motorPin2 = 11; //Orange
int motorPin3 = 12; //Red
int motorPin4 = 13; //White
int delayTime = 500;
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(motorPin1, HIGH);
digitalWrite(motorPin2, LOW);
digitalWrite(motorPin3, LOW);
digitalWrite(motorPin4, LOW);
delay(delayTime);
digitalWrite(motorPin1, LOW);
digitalWrite(motorPin2, HIGH);
delay(delayTime);
digitalWrite(motorPin3, HIGH);
delay(delayTime);
digitalWrite(motorPin4, HIGH);
delay(delayTime);
You've given the pins nice names; why not use them?
Are you using logic-level MOSFETs?
We're a little short on detail here.
When posting code, please use the # icon on the editor's toolbar.
I'm not the neatest of coders but yes i should use them. The transistors i'm using are FCP11N60 which have a Vgs min of 3v and max of 5v.
When i get time tonight i will sketch up a diagram and upload it as ive got too much work to do it now, and thanks for your help.
No, those MOSFETs have a Vgs max/min of +/-30V if you look at the abs-max-ratings.
They have a gate threshold voltage of between 3 and 5V - if you look carefully thats the gate voltage at which 250uA can flow between source and drain. Typically a MOSFETisn't "on" till the Vgs is several volts above threshold - in fact the threshold tells you the off-point not the on-point.
If you look at the Rds(on) rating its given for Vgs=10V - this is the clear indication that its not logic-level. Logic-level MOSFETs always have the Rds(on) given for Vgs=4.5V (sometimes lower). Data sheets usually say "logic level" if its logic level as well - particularly for TO220 packages since its not the normal case.
Ok, should have looked more closely at the datasheet. I have had them switching on and working from these MOSFETS using the 5v outputs though, its just odd that it will work for 3 of the pins/mosfets but not the 4th on (but the pin/mosfet that doesnt work has changed to another for no reason that i can see?)
rarts:
Yes, you need to use logic level mosfets. Look over this data sheet and see the difference is gate voltage specs compared to what you are trying to use:
Thanks for the link, guess i am getting lucky with some of the mosfets switching on at a Vgs of 3v. i'll see where i can get those in the UK. Cheers
Maybe if you'd put that vital and obvious detail in your first post, we could have saved a great deal of time.
Sorry but i didnt have that detail untill this morning otherwise i would have put it in when i started the post
In general if you don't know where the problem lies then provide all the detail you can (datasheets/schematic/board/code/power supply details)... The threshold thing with FETs is a common issue with newcomers to circuitry, but datasheet authors are writing for people who've understand the basic principle of operation of things like transistors...
