complete noob to electronics and I'm having difficulties with using a mosfet board. I'm using a 12v battery to power lighting one a timing loop. I've verified the loop is working correctly through the serial monitor. below is a picture of the setup, as I don't know circuitry schematics yet.
be80be:
You do know you can't put them all on the same heat sink like you have them
That's one of the dumbest comments I've ever seen: clearly, since OP already has them on one heat sink as you acknowledge, s/he obviously does not know that.
CrossRoads:
What's wrong with 13? The LED driven by it (buffered by a voltage comparator) won't affect anything.
Flasing during bootup.
Don't know if every Uno has this "feature".
be80be:
You do know you can't put them all on the same heat sink like you have them you have the drains all together
you have to insulate them.
Well spotted. It seems OP has lifted the mosfets from the board, and put a heatsink on them.
Not ok if you don't isolate the drains from the aluminium with mica/silpads and plastic TO-220 washers.
Leo..
Thank you for the help!! and for the notice of the heat sync. these LED strips don't use that many amps, and the mosfets are rated to handle 30amp. at what point is a heat sync actually necessary. I'm also going to be running a pump that has a draw of 9amps. I don't want to roast any boards.. well.. any more..
Four independent (not touching each other) L-shaped or U-shaped pieces of aluminium profile, with the mosfets flat on the board, could be easier.
Leo..
juggerHorn:
But back OT: I'm wondering if the fact that an IRF540 is not a logic level mosfet is part of the problem.
Mentioned that in my post, but had to correct it.
OP seems to have the opto coupler version, where the mosfets gates are driven by the supply on the secondary side.
Not sure about the exact drive voltage, but it's likely more than 5volt.
I think I've seen a diagram somewhere on the net.
Leo..
midiean:
The RDS(ON) is 77 mΩ for the IRF540. You should be able to dissipate at least 1W without heat sink, so up to 3.6A you should be OK.
