Anybody have suggestions for MOSFET transistors that work with the 5V from an Arduino? I'm looking for something from DigiKey or Mouser.
I read that part# FQP50N06L from Fairchild was 'logic-level', but I am new to datasheets, and I'm not sure what to look for.
Thanks!
You found the magic phrase, which is indeed "logic level". The key is to find a guaranteed value for Rds(on) when the gate voltage is 4.5V. For example, the NDP6060L:
http://www.fairchildsemi.com/ds/ND/NDB6060L.pdf
When searching at Digi-Key our Mouser use search options that limit the search to those MOSFET's which have guaranteed Rds(on) values at 4.5V and you should be finding all the logic-level MOSFET's.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
If you're driving lots of current, make sure you get a part with low Rds also, like down in the 8-10ohm (0.010 , 0.008) range. The lower you get, the cooler it will run.
I've had good experience (a single project) with RFP30N06LE (coincidentally bought at Sparkfun)
Can anyone recommend a good small LL FET? Say in a SOT23 package, 200mA or thereabouts. I seem to be having all sorts of trouble finding one.
Rob
How about a 2N7002? It's only <100mA but it's super-cheap. Otherwise, the IRLML2402 is a good choice: Rds(on) of 250mOhms at 4.5V gate voltage. Rated for 20V.
The DIN Rail Mount kit for Arduino: quickly attach your Arduino to standard DIN rail
Thanks RC, they both look good.
Rob
