Most efficient way to send data to serial?
Hello,
Sorry in advance for a long post with, probably, simple things but I just wanted to show what I tried to do to send data as fast as possible.
I made a program that measures rpm of a wheel in a dynamometer, then sends it to serial port and a c++ applications reads it, measures torque/power and draws a graph. The problem is the time between impulses from a wheel has to be very accurate - the wheel has 60 teeth and max roller speed is going to be about 6000 rpm - that means 1 impulse will come every 166 microseconds. I noticed that while measuring itself goes pretty well so far there is 1 thing that takes massive amount of time for this task - the Serial.print, which I wanted to dedicate this topic to.
I made a few simple programs that measure time of a loop:
1st test (and general idea of a program):
#include <Streaming.h>
unsigned long s;
unsigned long test=0;
unsigned long test2=0;
void setup(){
Serial.begin(9600); // The higher speed the better, but delays between different ways are more visible on lower speed.
void loop(){
s=micros();
test=s-test2;
test2=s; //calculation that measures time between loops
Serial.print(test2);
Loop time: 1604us.
2nd test - Now I wated to test how much time the calculation itself needs so I made an array that collects 10 samples and then prints them all at once:
unsigned long test3[10];
int i=0;
void loop(){
s=micros();
test=s-test2;
test2=s;
test3*=test;*
i++;
if (i==10)
  • for (int a=0; a<10; a++){*
    Serial.print(test3[a]);
  • i=0;*
    [/quote]
    Output: 217401281212121212812
    No spaces/lines between numbers, because thats another test. Each calculation took either 8 or 12us and thats after I added array and counter (i). Loop time with serial.print increased from 1604us to 21740us.
    3rd test - Now I wanted to put “|” after each loop time:
    > if (i==10)
    > Serial.print("|");
    > i=0;
    Output: 33176|12|12|8|12|12|12|12|12|12
    Adding a single char increased time of a serial.print loop from 21740us to 33176us. I was wondering if its really that single char that caused it so I run more tests.
    4th test - 2 serial prints each loop, one with time, one with “|”:
    > void loop(){
    > s=micros();
    > test=s-test2;
    > test2=s;
    > Serial.print(test);
    > Serial.print("|");
    Output: 5400|
    Time increased from 1604us to 5400us. I was wondering if it was just the serial print or something else so now I wanted to serial print a string with number and “|”:
    > String test3;
    > char buf[50];
    > void loop(){
    > s=micros();
    > test=s-test2;
    > test2=s;
    > ltoa(test, buf, 10); //converts unsigned long to char
    > test3=buf; //test3 is now the number
    > test3=test3+"|"; //and now the “|” is added
    > Serial.print(test3);
    Output: 5200|
    Time from base loop increased from 1604us to 5200us, but lowered from double serial print from 5400us.
    I must admit I have no idea why adding the “|” increased time of the loop so much.
    Now as seen in 1st program I have a <Streaming.h> library attached, because I heard its more resource efficient, so I run a few tests on it too:
    5th test - same as 1st, just used Streaming instead of serial print:
    > void loop(){
    > s=micros();
    > test=s-test2;
    > test2=s;
    > Serial<<test;
    Output: 1604s
    Exactly the same as serial print usage. However I thought it may hasten multiple variables printing:
    6th test - Same as 4th, using Streaming instead of Serial print:
    > void loop(){
    > s=micros();
    > test=s-test2;
    > test2=s;
    > Serial<<test<<"|";
    Output: 5200|
    So indeed it lowered the time from 5400us to 5200us, as much as creating 1 String variable that contained both time and “|”
    Then I tried to create something similar my real program would send: rpm|delay+
    > int i=300;
    > void loop(){
    > s=micros();
    > test=s-test2;
    > test2=s;
    > Serial<<test<<"|"<<i<<"+";
    Output: 9360|300+
    I wasnt sure if it was the variable amount or chars amount in buffer that caused time to increase so much so last test I run was:
    > int i=30000;
    > void loop(){
    > s=micros();
    > test=s-test2;
    > test2=s;
    > Serial<<test<<i;
Output: 936030000
Time remained the same, even though variable amounts was lower. Im not quite sure how much time it takes to print few chars - 1604 means its about 400us per char, while 936030000 means its about 1040us per char - however it seems after certain value the 1040us per char remains the same (33176|12|12|8|12|12|12|12|12|12 = 1070us per char and there were some additional calculations).
Now my question is - is there any faster way to send data to serial port (except of increasing transmission speed, even 115200 costs a lot of time)?
1/960 = 1041.66 us
Can you save all the data. Then when done, send it?
steinie44:
Yeah, its possible. I think best solution would be collecting data in an array and sending it all at once. However an array maximum size would be about 6000, if I wanted to calculate rpm after each revolution. My Arduino Uno has 2KB SRAM so it wouldnt handle that big array. It has 32 KB flash memory, though so I could store the data there. The question is how big delays in loop would saving data in flash memory cause. Unless there is a better solution, of course, since flash has limited times it can be written.
You can't write to flash at runtime. People have reported getting faster baud rates than 115200 - try & see if you can get it going fast enough. Alternatively, consider using an arduino ethernet and send your data over UDP.
Your post is very long - I think my brain could only handle the executive summary.
In my experience (testing for another project) the Arduino can send data to a PC pretty close to the rate you would expect for the chosen baud rate - so over 11000 chars per second at 115200 baud. And I think it will work at higher baud rates as well - but the Arduino Serial Monitor won't - I think that may be a Java limitation.
I don't think I tested for the time taken to send a single character - there may be some extra overhead.
One possibility, with limited Arduino RAM, is to read the data into a circular buffer and send it from the buffer every time 10 or 50 bytes (or whatever) is available. The reading could continue while the serial data is being sent.
I suspect you will find that Serial.write is faster as it doesn't convert values into their string equivalent. Remember that Serial.print() for an unsigned long will have to produce a lot of characters before anything caan be passed to the serial buffer.
I also would do my test timing differently - I would repeat whatever I want to measure 1000 or 10000 times and measure the total time taken.
...R
