Most limiting factor of arduino
Let's say That I want to use an arduino uno in a project where it would be subjected to all kinds of extremes. Very high and low temperature, high shock (mechanical shock, I.E. G-forces, dropping, jarring, etc.) High pressures, vacuums, etc.
Without pulling the datasheet on every single component, (and, not that I expect any of you to do this for me, just if you know off-hand or could point me a direction) what components should I be worried about?
Thanks
Crystal, and any non-soldered connections.
USB connector, power connector, maybe reset switch (dirt ingress and moisture).
Water
The programming skills of the person writing the code.
Most commercial components are only specified to work between 0 and 70C, using military grade components can push this at both ends but also pushes the cost a great deal, but you cant get much to work at below -30C and above 100C. Outside those you are better trying to engineer a climatic control for the electronics.
