Motion detection with ultrasound sensor SR04
Hi all,
I got a ultrasonic sensor SR04 and I want to create a simple project with it, which is a motion detector to trigger a photo camera.
I thought it could work like this:
1-Place the sensor a fix it somewhere against a fix object (wall, or whatever).
2-Take some readings of the distance and make an average of it
3-The monitor the distance and if the read distance drops from the average (by some factor) then trigger the camera.
I thought it was pretty straight forward but I came to an issue I don’t know how to address. My sketch is the following:
#define trigPin 13
#define echoPin 14
int mean;
int totalMean;
int duration, distance;
boolean calibrated=false;
boolean waited=false;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
void distanceCalculator(){
      digitalWrite(trigPin, HIGH);
      delayMicroseconds(1000);
      digitalWrite(trigPin, LOW);
      duration=pulseIn(echoPin, HIGH);
      distance=(duration/2)/29.1;
void loop(){
     if (calibrated==false){
       calibrate();
     }else{
     distanceCalculator();
     //delay(100);
     if (distance<0.90*totalMean){
     Serial.print(" Shoot ");
     Serial.println(distance);
void calibrate(){
  mean=0;
  totalMean=0;
    for(int i=1; i<101; i++){
       mean=mean+distance;
       delay(50);
       if (i==100) totalMean=mean/i;
      calibrated=true;
      Serial.println("");
      Serial.print(totalMean);
      Serial.println(" Calibrated!");
with this code the calibration works ok. However, when the loop goes into “monitoring” (calibrated==true), the readings are erroneous, and the Serial Monitor goes crazy printing small distances. If I add a delay (commented out above) it gets better. Not perfect, but better.
I would like to know what am I missing here. Any ideas?
Thanks in advance!
