hello , i want to ask about mpu6050 motion code ,if there is any motion i want to make the light off ........and if there is no motion i want the mpu 6050 to read 5 time after it to make sure that there is no motion and after that turn on the light ,,,,
and if there are any motion during this 5 read to back from begin or to the motion part
@ahmadasfan
The installation and troubleshooting section is not for your project it is getting the overall system working. As this is clearly about a project you want to do I have moved the post here. Please be more careful where you post in future.
Yes but only of people. So it will trigger when the sensor sees moving people (or other source of IR), or the sensor is moved in front of moving or still people.
Pir will detect heat source changes.
Trees etc in range can trigger pir sensors, also motor vehicles, anything that changes a heat source across the zones of the pir lens.
