Motion/Movement Sensor
Hi looking for a project that will build a motion/movement sensor. I'm not talking about one using a PIR which can detect movement near an object, but more if someone tries to move an object then an alarm sounds. I imagine if there is something out there it might use a mercury tilt switch or something similar.
Thanks for any guidance!
Wayne
A "shake switch" should work, and is available in several sensitivities: Fast Vibration Sensor Switch (Easy to trigger) : ID 1766 : $0.95 : Adafruit Industries, Unique & fun DIY electronics and kits
Thanks for this. Looks much the same as a tilt switch so I’ll check them both out!
Wayne
I've used this in the past
Aliexpress
