Motion Sensor Keep Relay On For Certain Time
I have a motion sensor that turns a relay on when motion is detected. The relay is hooked up to a light.
I want to add a timer that will control how long the relay stays on before turning off again. I don't want to use delay because that will then cause the code to stop. I'd like the light to stay on for a period of time while the code still runs.
How can I accomplish this?
int motionSensor = 2;
int timer = 100; // set the global delay
#define RELAY_1  3
#define RELAY_2  4
#define RELAY_3  5
#define RELAY_4  6
  pinMode(motionSensor, INPUT);
  pinMode(RELAY_1, OUTPUT);
  pinMode(RELAY_2, OUTPUT);
  pinMode(RELAY_3, OUTPUT);
  pinMode(RELAY_4, OUTPUT);
  digitalWrite(RELAY_1,HIGH);
  digitalWrite(RELAY_2,HIGH);
  digitalWrite(RELAY_3,HIGH);
  digitalWrite(RELAY_4,HIGH);
  int motionSensorVal = digitalRead(motionSensor);
  if (motionSensorVal == HIGH) {
    Serial.print("Motion detected!");
    Serial.print("\n\n");
    digitalWrite(RELAY_1, LOW);
    delay(2000);
    Serial.print("No motion detected.");
  delay(400);
Take a look.:
Timing starts when sensor in not trigged
#define RELAY_1  3
#define RELAY_2  4
#define RELAY_3  5
#define RELAY_4  6
boolean r1_on; // relay1 on
long timeOff; // timestamp when r1 is to be turned off
const int secs_on=30; // seconds with light on
    r1_on=true;
    timeOff=millis()+1000*secs_on;
  } else
  if (r1_on & millis()>=timeOff)
    r1_on=false;
Thank you for your reply.
The timer is not working. When I Serial.print time0ff the value changes for some reason? Wouldn't that be constant?
After the loop finishes the relay shuts off.
EDIT: It started working suddenly. Nevermind ;).
One thing I noticed is when you set the secs_on number to a value a little higher than 30, the timeOff value becomes negative and the timer does not work.
I tried using absolute value to make it positive but that did not work. It does not appear to be calculating it correctly. Any suggestions?
