I'm currently trying to familiarize with my 28BYJ-48 motor with my Arduino Uno.
When the motor is plugged into the 5V pin, it perfectly work whereas when it's plugged into the pin 3 and I put this pin HIGH, the motor is too weak to turn.
Is it normal ?
Thank you for your help and sorry for my english, I'm french.
Rémi
Yes, but very bad for the Arduino. NEVER try to power a motor or servo from an output pin. You will destroy the pin and/or the Arduino.
Motors and servos should also not be powered by the 5V pin, as it is not designed for such a heavy load. Use a separate motor/servo power supply and connect the grounds (negative leads).
An output pin can be used to switch on a motor power supply using a transistor or a relay, as shown in this diagram.
Any inductive load like a motor, relay, solenoid, etc will kick back large voltages on turning off the
current abrubtly.
You always need to design protection components into any circuit driving such a load, and microcontroller
pins do not have enough protection typically.
Also they cannot supply enough current for a heavy load like a motor.
So directly connecting a motor to Arduino pins is likely to not work at all and to damage the Arduino.
