motor alarm
Hi All, I'm very new to arduino programming
I''m trying to make the alarm high when the brake is high
i.e both functions execute at the same time, pls can you help
Motor Shield 1-Channel DC Motor Demo
by Randy Sarafan
For more information see:
int LxAlarm = 6;
int Brake = 9;
int Direction = 12;
int Speed = 3;
//Setup Channel A
pinMode(12, OUTPUT); //Initiates Motor Direction on Channel A pin
pinMode(9, OUTPUT); //Initiates Brake on Channel A
pinMode(3, OUTPUT); //Initiates Speed (PWN) on Channel A
pinMode(A0, OUTPUT); //Sense current
//Setup for level crossing alarm
pinMode(6, OUTPUT); //Initiates alarm at PIN 7
void loop(){
// if (Brake == HIGH)
// analogWrite (LxAlarm, 255);
//forward @ full speed
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
analogWrite(3, 180); //Spins the motor on Channel A at full speed
delay(4000);
digitalWrite(9, HIGH); //Engage the Brake for Channel A
delay(4000);
analogWrite(LxAlarm, 255);
delay(4000);
delay(4000);
delay(4000);
//backward @ half speed
digitalWrite(12, LOW); //Establishes backward direction of Channel A
analogWrite(3, 100); //Spins the motor on Channel A at half speed
delay(4000);
delay(4000);
It isn't clear to me what it is you want to do.
You're driving the brake, so you know when it is HIGH.
Please remember to use code tags when posting code.
Don't use delay() in your sketches.
You freeze your sketch for that period of time.
Use the BWD BlinkWithoutDelay technique, an example is in the IDE.
Read Robin2's discussion:
http://forum.arduino.cc/index.php?topic=223286.0
