I tried to control a motor using Arduino Uno , HC-05 bluetooth module and a L298N driver module.
This is my code
int enA = 9;
int in1 = 4;
int in2 = 5;
int enB = 10;
int in3 = 6;
int in4 = 7;
int motorSpeedA = 0;
int motorSpeedB = 0;
int val = 0;
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
Serial.begin(38400);
//Read input from bluetooth module:
if ( Serial.available())
val = Serial.read();
//Input key switch
switch (val) {
case '0':
analogWrite(enA, 0);
analogWrite(enB, 0);
//Code when no key is pressed
case '1':
// Set Motor A forward
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Set Motor B forward
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);//Code when UP key is pressed
for (int i = 255; i < 256; i++)
analogWrite(enA, i);
analogWrite(enB, i);
Serial.println("<Forward>");
if (i = 254)
i = 254;
Serial.println("<Setting Motor Forward>");
case '2':
// Set Motor A backward
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Set Motor B backward
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
for (int i = 150; i < 256; i++)
Serial.println("<Backward>");
if (i = 255)
i = 150;
//Code when DOWN key is pressed
case '3':
analogWrite(enA, 180); //speed 0 - 255
analogWrite(enB, 180); //speed 0 - 255
Serial.println("<Left>");
//Code when LEFT key is pressed
case '4':
//Code when RIGHT key is pressed
Serial.println("<right>");
case '5':
//Code when X key is pressed
motorSpeedA = 0;
case '6':
//Code when O key is pressed
motorSpeedB = 0;
default:
motorSpeedA = 255;
motorSpeedB = 255;
// default code (should never run)
when I send the codes I hear a buzzing sound from the motor but it does not spin.
What could be the reason for this?????
8) 8) 8)
My circuit is attached below
