Motor changes speed while sending a steady PWM signal
Hi everyone
new to motor controls with Arduino and started playing with it lately
using:
IBT_2 H-bridge motor controller
Arduino MEGA
Need For Power 24V vibration motor
2*12 V batteries in line to create 24V
I was able to control my motors using the analogWrite command until I have noticed something weird: when the motor works it runs at a changing speed even if the code supplies only one PWM value
for example:
If I supply a PWM signal of 160 the motor controller will be outputting what seems to be a randomly changing voltage between 17.5V-18.2V
I can also hear and see the motor running at different speeds according to the different voltages
const int m1_Vib_Right_Pin = 11; //output PIN - right vibration motor PWM signal
const int m2_Vib_Left_Pin = 12;  //output PIN - left vibration motor PWM signal
int m1_Vib_Right_PWM = 160; //output VALUE - PWM value to vib motor
int m2_Vib_Left_PWM = 160;  //output VALUE - PWM value to vib motor
  pinMode(m1_Vib_Right_Pin , OUTPUT);
  pinMode(m2_Vib_Left_Pin , OUTPUT);
  analogWrite(m2_Vib_Left_Pin, m2_Vib_Left_PWM);
  analogWrite(m1_Vib_Right_Pin, m1_Vib_Right_PWM);
Is this normal? how do I minimize the speed changes during work?
tried also switching to a different type of motor controller with all other parts of the system intact and the problem had repeated itself.
Does it happen with only 1 motor connected?
Please provide specs / links for the devices you are using.
Is load of the motor constant?
to johnerrington
motor controller - IBT-2 H-Bridge with Arduino – Dr Rainer Hessmer
motor - Need-For-Power Motor - Micro DC Motors
I have checked it with only 1 motor connected and the problem still occurs
to Smajdalf
Not sure if the load is constant, the motor's body is held by a metal band to an arm and is spinning with nothing connected to it but the weights that make the vibration.
Will a changing load affect my output voltage? I am not using any type of encoder/ HALL sensor
It is possible. More load -> higher current requirement -> more voltage drop in power supply -> lower motor voltage -> lower speed.
You shouldn’t be performing the analogWrite so often. It can have side effects. Try
  delay(100);
barbumble:
to johnerrington
to Smajdalf
Recall the science/physics class about spinning weights/gyroscope? Ever ride a bicycle or a motor cycle. What happens when you turn a spinning wheel/weight? It takes force to make it tuen. The motor, in your case, has to supply that force and that makes it work harder/run slower.
Paul
@Paul_KD7HB has oversimplified a bit.
The motor has INERTIA. So it takes force to change its speed.
Also the mass is eccentric so the motor needs to supply power continuously for the energy conversion
electrical energy - mechanical energy.
Neither of these would cause a changing speed.
If SOMETHING (eg another strong vibration) made it easier or harder for the motor because of interference that could cause the speed to change
which is why i asked if it happened with just a single motor connected.
@aarg has hit the nail on the head. when you
you are setting a timer to generate the pwm. It will get so far - but then you are starting it again.
And the pwm is normally at around 480 or 960 Hz - so your loop is executing faster than the timer can generate a pulse.
another +1 to add to your collection aarg! ..and a +1 to the OP for starting a very interesting discussion!
If AVR Arduino is used the frequent analogWrite should not cause problems because the timers update only once per cycle. Unless Arduino SW screws this somehow.
