I am currently in the process of building a simple tank-style R/C vehicle. It uses the transmitter and electronics out of an old nikko R/C car, along with a motor shield and Tamiya tracked chassis with a dual-motor transmission. The shield is powered by a 2s Li-Po battery, and the Arduino is powered through the Vin.
Since the control system is not proportional, and the voltage is way higher than the motors should be able to take, the motors receive about a 50% PWM at full throttle.
Having tested the thing multiple times, the electronics are all in working order, and I'm pretty sure they are wired up correctly.
When I press forward on the remote, 4.9v should be applied to digital pin 4
back sends it to 5
right sends it to 6
left sends it to 7
That being said, here is the code:
pinMode(12, OUTPUT);//Left motor direction is output
pinMode(9, OUTPUT);//Left motor brake is output
pinMode(13, OUTPUT);//Right motor direction is output
pinMode(8, OUTPUT);//Right motor brake is output
pinMode(3, OUTPUT);//left motor output
pinMode(11, OUTPUT);//right motor output
pinMode(4, INPUT);//FWD power wire is input
pinMode(5, INPUT);//REV power wire is input
pinMode(6, INPUT);//R power wire is input
pinMode(7, INPUT);//L power wire is input
digitalWrite(9, LOW);//Sets left brake off
digitalWrite(8, LOW);//Sets right brake off
if (digitalRead(4) == HIGH && digitalRead(6) == HIGH){//If FWD and right
digitalWrite(12, HIGH);//both motors FWD
digitalWrite(13, HIGH);
analogWrite(3, 127);//left motor 50%
analogWrite(11, 56);//right motor 25%
else if (digitalRead(4) == HIGH && digitalRead(7) == HIGH){//if FWD and left
digitalWrite(12, HIGH);//both motors fwd
analogWrite(3, 56);//left motor 25%
analogWrite(11, 127);//right motor 50%
else if (digitalRead(5) == HIGH && digitalRead(6) == HIGH){//rev and right
digitalWrite(12, LOW);//reverse
digitalWrite(13, LOW);//reverse
analogWrite(3, 127);//left 50%
analogWrite(11, 56);//right 25%
else if (digitalRead(5) == HIGH && digitalRead(7) == HIGH){//rev and left
digitalWrite(12, LOW);//both rev
analogWrite(3, 56);//left 25%
analogWrite(11, 127);//right 50%
else if (digitalRead(4) == HIGH){//just fwd
digitalWrite(12, HIGH);//fwd
else if (digitalRead(5) == HIGH){//just rev
digitalWrite(12, LOW);//both fwd
analogWrite(3, 127);//both 50%
else if (digitalRead(6) == HIGH){//just right
digitalWrite(12, HIGH);//left fwd
digitalWrite(13, LOW);//right rev
else if (digitalRead(7) == HIGH){//just left
digitalWrite(12, LOW);//left rev
digitalWrite(13, HIGH);//right fwd
else{//The only situation this should cover is no input
analogWrite(3, 0);//no power to either
analogWrite(11, 0);
Hopefully the comments answer any questions about function you might have.
Now the main problem is that when nothing is being pressed, the motors just continue to do what they were last told to do. I suspect this is either a coding problem or something to do with hanging voltage. Are there any issues with the code? I don't think so, I went over it a million times, but I would like some people with more experience to check it.
Thanks in advance!
