Motor control h-bridge problems
If you do not have a voltmeter you need to get one. You should test the DC operation of your circuit with a voltmeter as the first step in debugging. You need to verify you are getting the expected voltages at the outputs given applied voltages at the inputs. If not, you need to step through the voltages at the internal nodes. Can't help you without that info.
