Motor control issues with ATTINY85
So I have a standard DC motor that I pulled from something some years ago. I don't know the specs on the thing but if i plug it into my arduino uno's 5V+ and GND- it runs just fine. So I wrote a simple code to upload to my ATTINY and see if I could control it. So far I haven't even tried PWM with it.
This is the code I wrote:
//ATtiny85 motor controller
const int motorForward = 1;
void setup() { pinMode(motorForward, OUTPUT); }
void loop() { digitalWrite(motorForward, HIGH); delay(1000); digitalWrite(motorForward, LOW); delay(1000);
So to my understanding it should run the motor for one second and then rest for one second if I have 1 of the motor's leads grounded and the other lead plugged into pin 1 on the ATTINY85 with the ATINY powered. Unfortunatley this is not the case and instead it will not turn my motor at all. Any reasons why?
Any reasons why?
Yes, your processor cannot drive a DC motor directly. Don't even try. Use a transistor.
If you go over to the Playground, you should find lots of examples of how to do this and what to use.
