Working on a split swing gate using wheels hubbed to windshield motors. Walks the
gate open.
Anyways was working code for both gates at once and because its my first sketch, i was struggling. So I am just working on ONE gate.
When I have code in to check the limit switches, the motor only twitches.
When I take it out … everything works good, just no limit switches.
Just need a little nudge, please
const int Request_Button = 4; // this is the open and close button
const int Pot_Setting = A1; // these are the pins we get the requested spd
const int Motor_Spd_Pin = 5; // these are the pins where we send the speed
const int Gate_Direction = 7; // these are the pins where we send dir info
const int Closed_Sensor = 11; // these pins are from the limit switches
const int Open_Sensor = 2;
unsigned long Previous_Time = 0; // the time var's are for timing the opening
unsigned long Current_Time = 0; // and closing making sure it isn't stuck
int ledpin = 13;
int i = 0;
int Gate_Speed = 0; // these var's will be assigned the value of the
int far_enough = 0;
// is sent to the PWM motor spd pins 5 & 6
String(Gate_Status) = "Open";
String(Requested_Action) = "Closeit";
bool Time_To_Slowdown = false;
bool Calc_Done = false;
// note that motor_A&b_Spd_pins are not here because you don't have
// to declare pinmode when using analogWrite. For reference pin 5
pinMode(Gate_Direction, OUTPUT); // pin 7
pinMode(Closed_Sensor, INPUT_PULLUP); // pin 11
pinMode(Open_Sensor, INPUT_PULLUP); // pin 2
pinMode(Request_Button, INPUT_PULLUP); // pin 4
pinMode(Pot_Setting, INPUT); // pin A1
pinMode(ledpin, OUTPUT);
if (digitalRead(Request_Button) == 0) // Pin 4 grounded
Move_The_Gate(Requested_Action);
Flip_Request();
void Move_The_Gate(String request)
Calc_Done = false;
Time_To_Slowdown = false; // this is for a soft landing
Previous_Time = millis();
Gate_Speed = analogRead(Pot_Setting); // pin A1 - get requested speed
if (request == "Closeit")
digitalWrite(Gate_Direction, HIGH);
digitalWrite(Gate_Direction, LOW);
do
Current_Time = millis();
if (Current_Time - Previous_Time >= 3000) // After 3 secs, trigger slow down in motor
Time_To_Slowdown = true;
if (Current_Time - Previous_Time >= 7000) // after 7 secs turn motor off and return
analogWrite(Motor_Spd_Pin, 0);
return;
if (Time_To_Slowdown && !Calc_Done) // the motor is slowed down to make soft landing
{ // and we only want to change speed once
Gate_Speed = Gate_Speed * .50;
Calc_Done = true;
analogWrite(Motor_Spd_Pin, Gate_Speed); // finally the PWM can be sent to the motor
////// this next bit of code checks both
////// limit switches. sketch doesn't like it because
///// the motor only thinks about going (little jiggle)
//// with out this code everything works good but no limits
far_enough = Chk_Limit(); // this looks at all the limit switches
if (far_enough == 1)
{ // if any limit switch is triggered
analogWrite(Motor_Spd_Pin, 0); // turn motors off and return
return;
while (true);
int Chk_Limit()
if (!digitalRead(Closed_Sensor) || !digitalRead(Open_Sensor))
return 1;
else;
return 0;
//******** code has changed several times so some
//******** functions may not be used
bool Request_Is_Received()
return !digitalRead(Request_Button); // pin 4
bool Gate_Is_Closed()
return !digitalRead(Closed_Sensor);
bool Gate_Is_Open()
return !digitalRead(Open_Sensor);
//********** for debugging
void blinkit(int numtimes)
for (int i = 0; i <= numtimes; i++)
digitalWrite(ledpin, HIGH);
delay(200);
digitalWrite(ledpin, LOW);
delay(100);
void Flip_Request()
if (Requested_Action == "Openit")
Requested_Action = "Closeit";
return;
if (Requested_Action == "Closeit");
Requested_Action = "Openit";
// for(int C = 0;C < 256; C++){ this is some softstart code
// analogWrite(MotorPin, C); I can use if needed
// delay(10); delay determinces how slow
