Hey there,
I have spend hours trying to figure this out, but I dont get it to work.....
I want to use a simple H-Bridge to control a Dc Motor bidirectionaly.
First I used 2 LEDs to symbolize the direction:
int fornpnPin = 8; // forwards Pin npn
int revnpnPin = 9; // reverse Pin npn
int forpnpPin = 10; // forwards Pin pnp
int revpnpPin = 11; // reverse Pin pnp
digitalWrite(forpnpPin, 1);
digitalWrite(fornpnPin, 1);
analogWrite(revpnpPin, 0);
digitalWrite(revpnpPin, 1);
digitalWrite(revnpnPin, 1);
analogWrite(forpnpPin, 0);
delay(3);
I know you can make 2 LEDs blink in much simpler ways bit I used it to check the circuit and they blinked/change accordingly.
When I now use the input Values of a potentiometer to control them it is just doing crazy stuff...
int potPin = A0;
int potValue = 0;
int potValuelow = 0;
int potValuehigh = 0;
int forPin = 8;
int revPin = 9;
int forValue = 0;
int revValue = 0;
int forpnpPin = 10;
int revpnpPin = 11;
potValue = analogRead(potPin);
potValuelow = max(potValue, 511);
potValuehigh = min(potValue, 512);
forValue = map(potValuelow, 0, 511, 255, 0);
revValue = map(potValuehigh, 512, 1023, 0, 255);
if (forValue >= 0)
analogWrite(forPin, -forValue);
if (revValue >= 0)
analogWrite(revPin, -revValue);
Serial.print("potentiometer = " );
Serial.print(potValue);
Serial.print("\t");
Serial.print("forward = ");
Serial.print(-forValue);
Serial.print("\t");
Serial.print("reverse = ");
Serial.println(-revValue);
delay(3);
The Serial monitor gives me the right values as I have planed. So probably the error lies in the digital/analogWrite??
If necessary I can upload some schematics of the circuit later. But there shouldent be a problem...? As far as I can say.
Please keep it simple as I am just a beginner...
Thanks for any help and suggestions
