Motor control with joystck problem
I found a sketch online that supposedly allows me to control a motor with a joystick. but the motor moves by itself even though I'm not pushing on the joystick. can anyone please tell me a better way to do this ot whats wrong with the sketch.
//motor
int in1 = 5;
int in2 = 6;
int joyVer = A0;
int MotorSpeed1 = 0;
int joyposVer = 512;
void setup(){
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
void loop(){
joyposVer = analogRead(joyVer);
if (joyposVer < 460)
digitalWrite(in2, HIGH);
joyposVer = joyposVer - 460;
joyposVer = joyposVer * -1;
MotorSpeed1 = map(joyposVer, 0, 460, 0, 255);
else if (joyposVer > 564)
digitalWrite(in1, HIGH);
MotorSpeed1 = map(joyposVer, 564, 1023, 0, 255);
MotorSpeed1 = 0;
if (MotorSpeed1 < 100)MotorSpeed1=0;
Where online? What motor? What motor driver?
You keep calculating MotorSpeed1 but it's never used for anything. So either you haven't copied the sketch correctly or it wasn't a good one to copy. Certainly not if you think it's going to control the speed of the motor.
Also it may be worth putting some Serial.prints in to see what values you are actually getting from your joystick.
Steve
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What does happen when you move the joystick?
