motor control with ultrasonic sensor
hey hope you guys can help! i am trying to get my motor sheild to be controlled by the ultrasonic sensor for movement. this is all powered by an arduino mega 2560 board. arduino does not really like my code so i was wondering if you can check it over and problem solve it. here is it-
const int EchoPin = 2; // Ultrasonic input
const int TrigPin = 3; // Ultrasonic signal output
const int leftmotorpin1 = 8; //signal output of DC geared motor
const int leftmotorpin2 = 9;
const int rightmotorpin1 = 10;
const int rightmotorpin2 = 11;
int currDist = 0; // distance
void setup() { pinMode(EchoPin, INPUT);
for (int pinindex = 3; pinindex < 8; pinindex++) {
pinMode(pinindex, OUTPUT); // set pins 3 to 10 as outputs
currDist=MeasuringDistance(); //measure front distance
if(currDist >20)
{ else { nodanger ();
else if (currDist <10)
backup();
randTrun();
else { //whichway();
randTrun();
//measure distance, unit:cm
long MeasuringDistance() {
long duration;
//pinMode(TrigPin, OUTPUT);
digitalWrite(TrigPin, LOW);
delayMicroseconds(2);
digitalWrite(TrigPin, HIGH);
delayMicroseconds(10);
//pinMode
(EchoPin, INPUT);
duration = pulseIn(EchoPin, HIGH);
return duration / 29 / 2;
// forward
void nodanger()
digitalWrite(leftmotorpin1, HIGH);
digitalWrite(leftmotorpin2, LOW);
digitalWrite(rightmotorpin1, HIGH);
digitalWrite(rightmotorpin2, LOW);
delay(1000); return; }
//backward
void backup() {
digitalWrite(leftmotorpin1, LOW);
digitalWrite(leftmotorpin2, HIGH);
digitalWrite(rightmotorpin1, LOW);
digitalWrite(rightmotorpin2, HIGH);
void totalhalt()
return; delay(500);
//turn left
void body_lturn()
totalhalt();
//turn right
void body_rturn()
totalhalt();
void randTrun()
long randNumber;
randomSeed(analogRead(0));
randNumber = random(0, 10);
if(randNumber > 5)
{ body_rturn();
{ body_lturn();
post your code in code tags thank you!
"arduino doesn't like my code" is pretty vague. What error do you get exactly?
Hi, before posting your code, in the IDE select TOOLS then AUTOFORMAT that will line your code up. Also what do you mean by
Does it compile and load to the arduino? A quick check shows you have too many left {, The problem is not far below the void loop(){ The if statement is very confusing.
Tom.... :)
