I can rotate my clearpath servo motor with: "RampToVelocity(-500,100);"
Is there a similar function to contol the motor by position.
I have tried "MoveToPosition" but I receive the following error:
'MoveToPosition' was not declared in this scope
I have edited the lines 58 and 60 of the following code and commented out lines 62-71.
I now see I need to implement "MoveToPosition" similar to lines 77-112
Any suggestions??:
TekTips2 - program to highlight Arduino wiring to a Teknic ClearPath integrated servo motor
Author is Brendan Flosenzier, 1/2/2018
Program uses a "MCVC" (Motion Control Velocity Control) ClearPath servo motor
Operating Mode is the "Manual Velocity Control"
TekTips Video: Wiring a ClearPath motor to an Arduino micro controller
//Wire colors refer to a standard Teknic ClearPath controller cable
const int Enable = 6; // ClearPath ~enable input; +enable = BLU wire; -enable = ORN wire
const int InputA = 8; // ClearPath Input A; +InputA = WHT wire; -InputA is BRN wire
const int InputB = 9; // ClearPath Input B; +InputB = BLK wire; -InputB = YEL wire
const int HLFB = 4; // ClearPath HLFB Output; +HLFB = GRN wire; -HLFB = RED wire
void RampToVelocity(int finalVelocity, double RampTime=0);
void DoSinusoid(int Amplitude,double Period);
int CurrentVelocity=0;
int VelocityResolution=1;
int DwellTime = 500; // desired time (ms) for ramp and constant velocity
//Define I/O pins
pinMode(Enable, OUTPUT);
pinMode(InputA, OUTPUT);
pinMode(InputB, OUTPUT);
//pinMode(HLFB, INPUT_PULLUP);
pinMode(HLFB, INPUT);
//STart Serialoutput for dubugging
// start off by ensuring thet the motor is disabled before proceeding
digitalWrite(Enable, LOW);
delay(DwellTime);
// set the two outputs to their initial states
digitalWrite(InputA, LOW);
digitalWrite(InputB, LOW);
// Enable motor to start sequence
digitalWrite(Enable, HIGH);
delay(DwellTime);
// end of setup code
// put your main code here, to loops indefinitely:
MoveToPosition(640,500); //Goal is to move 1/10 revolution in 1/2 second (This line was previously RampToVelocity
MoveToPosition (640,500); //Goal is to move 1/10 revolution in 1/2 second (This line was previously RampToVelocity
delay(DwellTime);
// RampToVelocity(-500,100); //Ramp to -500 RPM in .1 sec
// delay(DwellTime);
// DoSinusoid(100,1000); //Do a sinusoidal profile with an amplitude of 500 RPM in 1 sec
// RampToVelocity(1000); //Ramp to 1000 RPM as fast as possible
// RampToVelocity(0); //Ramp to 0 RPM as fast as possible
// DoSinusoid(100,1000); //Do a sinusoidal profile with an amplitude of 1000 RPM in 1 sec
// end of main code, will loop indefinitely:
//Implementation of RampToVelocity function RamptTime defaults to 0 if not specified
void RampToVelocity(int finalVelocity, double RampTime)
//Calculate number of quadrature cycles needed to reach new target speed
double Increments = abs(finalVelocity-CurrentVelocity)/VelocityResolution;
//Calculate ramp time in microseconds to match the desired ramp time
double RampDelay = RampTime*1000/Increments;
for(int i=0; i<Increments;i++)
//Check which direction the quadrature signal must go in
if(finalVelocity-CurrentVelocity>0)
digitalWrite(InputA, HIGH);
digitalWrite(InputB, HIGH);
CurrentVelocity=CurrentVelocity+VelocityResolution;
CurrentVelocity=CurrentVelocity-VelocityResolution;
//If the required delay is very short use delayMicroseconds, other wise use delay (ms)
if(RampDelay<1000)
delayMicroseconds(RampDelay);
delay(RampDelay/1000);
//Implementation of DoSinusoid function
//Calculate number of quadrature cycles needed to reach the full amplitude (1/4 sin wave)
int Increments=Amplitude/VelocityResolution;
double delaytime; //(ms)
//Execute the first 1/4 of the sin ramping up to full amplitude
for(double i=1;i<=Increments;i++)
delaytime=Period*(asin(i/Increments)-asin((i-1)/Increments))/(2PI);
if(delaytime<10)
delayMicroseconds(delaytime1000);
delay(delaytime);
//Execute the 2nd 1/4 of the sin ramping back down to the original speed
for(double i=Increments;i>0;i--)
if(delaytime<10)
delay(delaytime);
//Execute the third 1/4 of the sin ramping up to full amplitude in opposite direction
if(delaytime<10)
delay(delaytime);
//Execute the last 1/4 of the sin ramping back down to the original speed
if(delaytime<10)
delay(delaytime);
Please use Code Tags </> to present code.
Links to the motor data sheet and library were helpful.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom...
