I am building an ROV i need to run 2 bilge pumps that draw 5 amps 7 max per motor. i need it to be bi directional and variable speed. i wil be running the motor off of a 75 foot run of 10 awg wire ran to a 12v car battery. The controllers will be housed in a sealed pvc pipe so low heat would be ideal. out of these or any others around the web which would best fit my needs im using a uno so the less pins the better.
Right., as long as you arrange for an external inverter. The Pololu board has separate A and B inputs. If you need A = not B at all times, as I do, you can use an inverter and avoid using an extra pin on the Arduino.
depth in water i know you can use a pressure transducer but they cost 120+ which is to much. i would be going about 10 feet deep so i need to measure about 7 psi. i am looking in to using a electronic oil pressure sensor which is about 15 i know it outputs 0-5v and is rated for 80 psi i need to look into if it will work for me. is the uno sensitive enough to work between 0-100 microvolts 1-8 psi or will i need to amplify it?
