Motor controller l9110 PWM problems
Hello,
I have a problem with my l9110. I want to make my motor drive in 2 speeds forward and backward. But when i type the code it only moves in forward direction and doesn’t change direction like it’s suppose to.
This is the basic code on which i am testing:
pinMode(D3,OUTPUT);
pinMode(D2,OUTPUT);
int h1=512;
int h2=1024;
int l=0;
analogWrite(D2,l);
analogWrite(D3,h1);
delay(300);
analogWrite(D3,h2);
delay(300);
analogWrite(D2,l);
analogWrite(D3,l);
delay(300);
analogWrite(D2,h1);
analogWrite(D3,l);
And i also tried another code for speeding up the motor. When i put it forward it speeds normally, but when it has to start speeding backwards it starts backwards but in full spreed. This is the second code.
analogWrite(D2,b);
for(i=0;i<=1024;i++){
analogWrite(D3,i);
delay(50);
if(i==1024){
analogWrite(D3,b);
analogWrite(D2,i);
delay(50);
I’v tried it on both Arduino and ESP and it’s the same result.
Which Arduino are you using? The UNO and other AtMega328 based Arduinos have a range of values for analogWrite() from 0 to 255.
