I'm back.
I have arrange what Steve pointed me yesterday and I arranged another things. It works bad but ..
When it starts the sensor calibrates and then the sensor detects the movement.
But without ant button pressed once movement is detected the motor starts following the directions of the button in Pin 9, if I push the 8 it changes direction but only if I am pushing when I leave it the motor returns to the other direction. I would need that the momentary pressure fix the direction until the next change.
When the movement stops the motor stops. But the PIR is not waiting for the transition (PAUSE TIME) to LOW.
Here the modified code
//VARS
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 30;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 10000;
boolean lockLow = true;
boolean takeLowTime;
const int pirPin = 2; //the digital pin connected to the PIR sensor's output
const int button1Pin = 8; // the number of the pushbutton1 pin
const int button2Pin = 9; // the number of the pushbutton2 pin
const int IN3 = 5;
const int IN4 = 4;
const int ENB = 3;
int button1State = 0; // variable for reading the pushbutton status
int button2State = 0; // variable for reading the pushbutton
//start serial connection
// initialize the pushbutton pin as an input:
pinMode(button1Pin, INPUT);
pinMode(button2Pin, INPUT);
digitalWrite(button1Pin, LOW);
digitalWrite(button2Pin, LOW);
// initialize the H-Bridge pin as an output:
pinMode (ENB, OUTPUT);
pinMode (IN4, OUTPUT);
pinMode (IN3, OUTPUT);
digitalWrite(IN3, LOW);
digitalWrite(IN4, LOW);
pinMode(pirPin, INPUT);
digitalWrite(pirPin, LOW);
//give the sensor some time to calibrate
Serial.print("calibrating sensor ");
for(int i = 0; i < calibrationTime; i++){
Serial.print(".");
Serial.println(" done");
Serial.println("SENSOR ACTIVE");
delay(50);
// read the state of the pushbutton values:
button1State = digitalRead(button1Pin);
button2State = digitalRead(button2Pin);
digitalRead(pirPin);
if (digitalRead(pirPin) == HIGH && millis() > 1000) {
if (button1State == HIGH){
// Motor one direction
analogWrite(ENB,220);
digitalWrite (IN4, HIGH);
digitalWrite (IN3, LOW);
else if (digitalRead(pirPin) == HIGH && millis() > 1000) {
if (button2State == HIGH);
// Motor other direction
digitalWrite (IN4, LOW);
digitalWrite (IN3, HIGH);
if (lockLow) {
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis() / 1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
else if (digitalRead(pirPin) == LOW) {
if (takeLowTime) {
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if (!lockLow && millis() - lowIn > pause) {
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause) / 1000);
delay(50);
analogWrite(ENB,0);
delay(50);
analogWrite(ENB,0);
Thank you
rudni
