Motor does not switch reverse in function while getting the signal for switch reverse bye can
Hello People!
i have some code here… the motor does not switch reverse when it gets a signal down when (down==1).it just go up when up==1 and stops when up=0 and down =0 but dont go down( turn the other side)while down==1 and up =0;.Can anyone tell me why and how you can write a working code?It works normal and goes up when up==1 after reach the enddestination in one way .It does not reverse.Whats the problem?
void motor()
if (up==1){
digitalWrite(m1,HIGH);
digitalWrite(m2,LOW);
if (up==0&&down==0||(down==1&&up==1)){
digitalWrite(m1,LOW);
if (down==1){
digitalWrite(m2,HIGH);
You need to post your entire sketch. What are you using to drive your motor? a shield of some type? a schematic would also be helpful
You have given the incomplete information. Provide more to understand and analize it
Since the (down == 1) is last, even if they are both 1 and the middle ‘if’ turns the motor off, the motor will immediately turn back on because down == 1.
Try this:
void motor()
  if (up==down)
    // Stop
  if (up)
    // Up
    // Down
Hi thanks for your reply when i try your code it gives an error like below.
Arduino: 1.8.13 (Windows 10), Board: “Arduino Nano, ATmega328P”
C:\Users\Cihan\OneDrive\Documenten\Arduino\send_encoder\send_encoder.ino: In function ‘void motor()’:
send_encoder:113:1: error: a function-definition is not allowed here before ‘{’ token
send_encoder:123:14: error: a function-definition is not allowed here before ‘{’ token
send_encoder:153:13: error: a function-definition is not allowed here before ‘{’ token
send_encoder:180:1: error: expected ‘}’ at end of input
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
i made it error free and upload it, by taking out some brackets like below:
only the engine still does not reverse while the down is 1 when, i look at the plotter and down==1 and engine does not do anything?
void motor()
if (up==down)
// Stop
if (up)
// Up
// Down
If down == 1 AND up == 1, that means STOP. Did you check the value of up?
void motor()
  if (up != down)
    if(up)
    { // <---- This should be '}'
   // <---- And there should be a '}' here
hi if i put:
if (up != dowqn)
if(up)
if(down)
else{
it does go up and when i push to down it also goes up untill -32357 far behind the highest destination and then stops, while i can see at serial monitor down=1.
UP and DOWN both set m1 HIGH and m2 LOW, just in different order. That’s why both move in the same direction.
yes i changed it and the code still blocks and doesnt goes down.only up
thank you for the contribution and help,i found the problem it was a disconnected wire from the motor driver to the nano :slight_smile:
