The motor a doesn't work when in4 is plugged in, and motor b doesn't work when in2 is plugged in. The code honestly worked 1 month ago, but when I connected it again, it didn't work. Is this problem normal or not? how do i fix this?
This is from this video how to make arduino obstacle avoiding car using L298N motor driver - YouTube
#include <Servo.h> //Servo motor library. This is standard library
#include <NewPing.h> //Ultrasonic sensor function library. You must install this library
//our L298N control pins
const int LeftMotorForward = 8;
const int LeftMotorBackward = 9;
const int RightMotorForward = 10;
const int RightMotorBackward = 11;
//sensor pins
#define trig_pin A1 //analog input 1
#define echo_pin A0 //analog input 2
#define maximum_distance 100
boolean goesForward = false;
int distance = 50;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
void setup(){
pinMode(RightMotorForward, OUTPUT);
pinMode(LeftMotorForward, OUTPUT);
pinMode(LeftMotorBackward, OUTPUT);
pinMode(RightMotorBackward, OUTPUT);
servo_motor.attach(7); //our servo pin
servo_motor.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
Serial.begin(2000000); // Starts the serial communication
void loop(){
int distanceRight = 0;
int distanceLeft = 0;
delay(50);
if (distance < 30){
moveStop();
delay(300);
moveBackward();
delay(400);
moveStop();
delay(300);
distanceRight = lookRight();
delay(300);
distanceLeft = lookLeft();
delay(300);
Serial.print("Distance: ");
Serial.println(distance);
if (distance >= distanceLeft){
turnRight();
moveStop();
else{
turnLeft();
moveStop();
else{
moveForward();
int lookRight(){
servo_motor.write(100);
int distance = readPing();
delay(100);
return distance;
int lookLeft(){
servo_motor.write(170);
delay(100);
return distance;
delay(100);
int readPing(){
delay(70);
int cm = sonar.ping_cm();
if (cm==0){
cm=250;
return cm;
void moveStop(){
digitalWrite(RightMotorForward, LOW);
digitalWrite(LeftMotorForward, LOW);
digitalWrite(RightMotorBackward, LOW);
digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
if(!goesForward){
goesForward=true;
digitalWrite(LeftMotorForward, HIGH);
digitalWrite(RightMotorForward, HIGH);
void moveBackward(){
goesForward=false;
digitalWrite(LeftMotorBackward, HIGH);
digitalWrite(RightMotorBackward, HIGH);
void turnRight(){
void turnLeft(){
