motor driver getting hot + cannot change the motor speed
i have a problem a motor driver FIPSD2M and it`s link
http://farespcb-eg.com/ServesPages/ProductInfo.aspx?PID=21&TypePage=Category&Cat=81
connected with motor and its specs below
http://ram-e-shop.com/oscmax/catalog/product_info.php?products_id=3304
and i have 2 roblems
1-i cannot change the motor speed using potentiometer (using potentiometer 100k ohm)
2-the IC L298 is getting hot, is this normal ?(the driver supports 2Amp /phase)
**and below is my arduino code ,i do not know what is the problem **
int pot=A0;
int Ena=10; //enable the driver
int Dir=8; // motor direction
int CLK=9; // motor speed
int val=0;
int mSpeed=0;
pinMode(Ena,OUTPUT);
pinMode(Dir,OUTPUT);
val=analogRead(A0);
mSpeed=map(val,0,1023,0,255);
analogWrite(CLK ,mSpeed);
It is normal for the driver to get hot.
The L298 won't deliver 2A without overheating and shutting down, and the motor can't handle 2A/phase either. To what value have you set the current limit?
This is not the way to control the speed and it won't work at all. The CLK input commands one step.
You should try using the Accelstepper library.
