Motor driver help
I am trying to make a robot that will detect an object and wil turn and I have found all of the necacary parts for it except for just one the motor driver, I will list the parts that I have already found...
Geared dc motor
https://www.amazon.com/gp/product/B01M02X1WJ/ref=ox_sc_act_title_5?smid=A35C93BBDX68G6&psc=1
Sparkfun pro micro mini 5v
Rechargeable Nimh 4.8v 2000 mAH battery
Hc-sro4 sensor 5v (not sure this would run on 4.8v)
Those are my specifications and if you see any problems that the combination of my components have please notafiy me!
Anyways to recap I need a motor driver that would run on 4.8v or less and I need the output to have a decent 3v or more if that's possible.
check the specs on the mini 4.8 may be too low especially if your driving the motor also check out this site
New Products : Adafruit Industries, Unique & fun DIY electronics and kits and look at the Mbot also they have parts you can use
Ops motor.
BQLZR 33x12mm 300RPM Metal Mini DC 6V Gearbox Gearwheel Motor Mini Reduce Speed Geared Electric Motor
Tom... :slight_smile:
I have some motors like that (sans gearbox) and I use a Pololu DRV8833 driver.
...R
Can the polu motor driver,controll two of those motors controlled on a board like adafruit trinket 5v or sparkfun pro micro 5v?
TORTLE_TECH:
I had assumed you would go to Pololu's website to get that information and all the other technical details so you can be sure it is suitable for your project.
Yes it can control 2 motors.
...R
