Motor driver not being activated
Soooo.... I got help from Robin2 with trying to wire up three motors to an Arduino, and it was finished in a way that let power go through the whole thing, but based on my wiring and my code- the motor drivers don't light up as they should- and the motors aren't moving.
I'm pretty sure it's a wiring problem and not a code problem, because the orange light on the Arduino lights up as if to say it's trying to use them. The aim of the project is to have three different buttons activate 3 different motors, but as of now- it's not working so great. I've attached an image of a sketch of what the circuit looks like now, and heres the code:
int Pin1 = 10;
int Pin2 = 11;
int Pin3 = 12;
int Pin4 = 13;
int Pin5 = 6;
int Pin6 = 7;
int Pin7 = 8;
int Pin8 = 9;
int Pin9 = 2;
int Pin10 = 3;
int Pin11 = 4;
int Pin12 = 5;
int _step = 0;
boolean dir = false;// false=clockwise, true=counter clockwise
int count=0;
unsigned long previousMillis = 0;
unsigned long interval = 10000;
 pinMode(Pin1, OUTPUT);
 pinMode(Pin2, OUTPUT);
 pinMode(Pin3, OUTPUT);
 pinMode(Pin4, OUTPUT);
 pinMode(Pin5, OUTPUT);
 pinMode(Pin6, OUTPUT);
 pinMode(Pin7, OUTPUT);
 pinMode(Pin8, OUTPUT);
 pinMode(Pin9, OUTPUT);
 pinMode(Pin10, OUTPUT);
 pinMode(Pin11, OUTPUT);
 pinMode(Pin12, OUTPUT);
    int value = analogRead(A1);
  if (value > 650 && value < 1000) {
    Serial.println("Button1");
    motor1();
  } else if (value > 480 && value < 650) {
    Serial.println("Button2");
    motor2();
  } else if (value < 480) {
    Serial.println("Button3");
    motor3();
  delay(2);
void motor1() {
 switch(_step){
   case 0:
     digitalWrite(Pin1, LOW);
     digitalWrite(Pin2, LOW);
     digitalWrite(Pin3, LOW);
     digitalWrite(Pin4, HIGH);
   case 1:
     digitalWrite(Pin3, HIGH);
   case 2:
     digitalWrite(Pin4, LOW);
   case 3:
     digitalWrite(Pin2, HIGH);
   case 4:
   case 5:
     digitalWrite(Pin1, HIGH);
     case 6:
   case 7:
   default:
 if (currentMillis - previousMillis > interval) {
    if (dir == false)
      dir = true;
      delay(99999999999999999999999999999999999999999999999);
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
void motor2(){
 switch(_step){
   case 0:
     digitalWrite(Pin5, LOW);
     digitalWrite(Pin6, LOW);
     digitalWrite(Pin7, LOW);
     digitalWrite(Pin8, HIGH);
   case 1:
     digitalWrite(Pin7, HIGH);
   case 2:
     digitalWrite(Pin8, LOW);
   case 3:
     digitalWrite(Pin6, HIGH);
   case 4:
   case 5:
     digitalWrite(Pin5, HIGH);
     case 6:
   case 7:
   default:
    if (dir == false)
      dir = true;
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
void motor3(){
 switch(_step){
   case 0:
     digitalWrite(Pin9, LOW);
     digitalWrite(Pin10, LOW);
     digitalWrite(Pin11, LOW);
     digitalWrite(Pin12, HIGH);
   case 1:
     digitalWrite(Pin11, HIGH);
   case 2:
     digitalWrite(Pin12, LOW);
   case 3:
     digitalWrite(Pin10, HIGH);
   case 4:
   case 5:
     digitalWrite(Pin9, HIGH);
     case 6:
   case 7:
   default:
    if (dir == false)
      dir = true;
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
Fritzing diagrams are useless. Please post a clear hand drawn diagram, with clearly labeled connections.
So, you felt that posting in the Programming section was more appropriate than posting in the Motors, Mechanics, and Power section. Did you post your programming question there?
Im still not completely sure about the correctness of the code- because the problem is that the motor driver/motor aren’t being activated- but the orange light is saying it should be.
You have far too much code for someone who is not certain that the hardware is all connected correctly and is working.
ALL that loop() should be doing is calling motor1() until whatever it is that improperly named function does is done correctly. Then, you can read and print the value of the analog pin. When you know that that works, you can make the call to the improperly named function dependent on the analog value.
Ok. I've investigated by only trying to activate one of the motors- and it didn't work. It did the same thing (in that the orange light flashed, but the motor didn't do anything).
Wiring problem.
Ok. At this point, I must admit I'm completely lost. I'm think that the power being sent to the stepper motors isn't working somehow- but I don't know how to fix it- if you have any idea what the correct way to wire 3 motors to and Arduino correctly, that'd be awesome.
(Thank you for the help so far by the way)
