The driver has some LEDs that show the state of the output pins and it seems to work just fine with +5V on the input pins, or even when I touch the input pins. However, it does not work when I connect it to Arduino.
The circuits share a common ground.
The Arduino board is powered via USB.
The rest of the circuit is powered by a different power supply.
I've recorded a short video to show you the problem: - YouTube
Funny thing: When I plug the motor driver into Arduino (running pin13 blink) there's nothing happening. Arduino Pin 13 goes to motor driver input 1. Output 1 does not blink.
I have checked, Arduino outputs +4.8V to driver input 1.
BUT
If I touch input1 and input2 at the same time on the input board, output 1 and output 2 blink on the motor driver board along with ledpin 13 on Arduino.
This is probably some simple electronics mistake that I'm unaware of. Any ideas? Thanks!
Hi, even though it shows on the diagram, have you got all the grounds connected together, the arduino and the pcb and the power supply for the motor.
I notice that you are using one of the long protoboards, check that the two tracks that run the outside length of the board are continuous.
Some boards have a break in the track half way along.
Yes all grounds are connected. I have checked and double checked. Indeed the long lines on the protoboard only go halfway through the board, but I'm only using the right side of the board.
I think there may be an issue with my L298 chip.
@JimboZA - there's nothing fancy about that. Just common ground, different power supplies (USB for Arduino and external supply for the board and motor driver) and pin13 Arduino going to input 1 on the driver board.
I just found out there's an issue with the board. It was working alright last night, before connecting it to Arduino, but now I tested it again and it doesn't seem to behave properly.
Thank you, I'll post back once I find out what happened.
I used an LM317 regulator for providing 5V to L298N. That worked fine when I first tested the circuit, then at some point it stopped working when I connected to Arduino, which made me think Arduino had something to do with it. I redid the wiring and everything works now.
