I can't make the other if else occur. only W works
WASD with Q as stop
<CODE/>
pinMode(2, OUTPUT);//
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
pinMode(6, OUTPUT);
while (Serial.available() == 0)
if(Serial.read()=='W')
digitalWrite(2,HIGH);
analogWrite(5,255);
digitalWrite(4,LOW);
analogWrite(6,255);
else if(Serial.read()=='S')
digitalWrite(2,LOW);
analogWrite(5,255);
digitalWrite(4,HIGH);
analogWrite(6,255);
else if(Serial.read()=='D')
analogWrite(5,50);
analogWrite(6,50);
if(Serial.read()=='A')
analogWrite(5,50);
analogWrite(6,50);
if(Serial.read()=='Q')
analogWrite(5,0);
analogWrite(6,0);
<CODE/>
jim-p
April 22, 2024, 12:27pm
2
Don't put the Serial.read() in the if statements.
Do one Serial.read() right after the while statement and put the result into a int variable, then use that variable in the if statements.
String motion = "";
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
pinMode(6, OUTPUT);
while (Serial.available() > 0)
motion = Serial.read();
if(motion=='W')
analogWrite(5,255);
analogWrite(6,255);
else if(motion=='S')
analogWrite(5,255);
analogWrite(6,255);
else if(motion=='D')
analogWrite(5,50);
analogWrite(6,50);
if(motion=='A')
analogWrite(5,50);
analogWrite(6,50);
if(motion=='Q')
analogWrite(5,0);
analogWrite(6,0);
jim-p
April 22, 2024, 12:58pm
4
Make motion an int not string
Don't put the Serial.read inside the brackets.
Put it after the last bracket.
Put the while statement back to the way it was
jim-p
April 22, 2024, 2:38pm
5
Like this
int motion = Serial.read();
xydeathz:
String motion = "";
Avoid using Strings on Arduino. Due to poor memory management, they lead to program crashes, especially on AVR based Arduinos like the Uno, Mega, etc.
Use char variables instead. This is faster, takes less program memory and above all, is reliable :
char motion = Serial.read();
if(motion=='W')
ps0709
April 23, 2024, 9:40am
7
You can try using numbers, sometimes I encounter errors with using WASD
if(Serial.available()){
Serial.println(motion);
if(motion == '1'){
and then continue the code using numbers.
system
Closed
October 20, 2024, 9:51am
10
